Question about Vizio VX32L Television
Vizio 47' lcd
The tv's only problem is that it cannot be turned on OCCASSIONALLY.
The power light would light up but the screen would otherwise. After a few seconds the power light would also shut down.
  • 4 Answers
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Posted on Jan 23, 2008
6ya staff
SOURCE:
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
47" Vizio LCD
Sounds like incompatibility of video settings or loose cable. It is also possible that you have a bad power cable. Is it hooked up to anything else or is it just plugged into the wall only?
Nov 15, 2013 | Televison & Video
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
Mar 25, 2010 | Vizio SV470XVT 47 in. LCD TV
The screen on the my Vizio 47'' TV has gone black but the power is still on. Why have I lost my screen?
are you sure it is on the correct input?did you have a power surge? have you reset it?did it go while you where watching it or when you turned it on?does it have audio?
Jun 09, 2009 | Vizio VO47L 47 in. LCD TV
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
May 18, 2009 | Vizio VO47L 47 in. LCD TV
Vizio VX32L Television Logo
174 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
