Question about Brother MFC 7420 All-In-One Laser Printer
I want to receive fax in my pc but mfc-7420 (JAY) prints it on paper
I have installed brother mfc-7420 and also checked for Installation Diagnostics it prompts. sending and receiving fax are ok. I clicked link start receiving fax and that icon is on taskbar. But whenever I get fax mfc-7420 prints the fax instead of saving in PC.
Need help. Thank You.
  • ort91 Aug 28, 2008
    I plug my machine into the splitter but it doesn't pick up for faxes. what gives?
  • acker1820 Jan 12, 2009
    faxes save to PC for awhile, then stops. The saved ones can be viewed on paperport. reinstalling software solves the problem, but it reoccures.
    New Friend:
You may do better going online and signing up top a fax to emaiil solution. You may find that when your PC receives a fax direct that the machine will momentarily freeze. Also have a look at the windows fax software.
Posted on Mar 09, 2015
 how to send a fax
Posted on Apr 29, 2008
6ya staff
SOURCE:
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
When i am faxing do i put the paper up or down on this thing brother mfc-7420
Either lift the lid lay the paper in print side down, or put it into the document feeder print side up. In either case the top edge of the page should be at your left to appear right-side up at the receiving, but that's a minor point.
Sep 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
Dec 08, 2008 | Brother MFC-210 All-In-1 Print/...
How to print fax confirmation sheet - MFC-7420
first print out the help sheet, might be in reports then u have all the information at hand
Nov 21, 2008 | Brother MFC 7420 All-In-One Laser Printer
Pc fax msg
The display msg means that there are a few faxes in storage and they just need to be printed from the memory:
on my mfc-7440n:
Printing a fax from the
memory 6
If you are using the Fax Storage feature
(Menu, 2, 5, 1), you can still print a fax from
the memory when you are at your machine.
a Press Menu, 2, 5, 3.
Remote Fax Opt
3.Print Fax
b Press Start.
c Press Stop/Exit.
Aug 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Installation diagnostics
Hi press start the search type in the required fie name press enter then once it appears double click and it will open. Or you could right hand click copy and paste it back or on desktop
Thanks J
Feb 02, 2008 | Brother MFC 7420 All-In-One Laser Printer
Fax problem
I guess you run win xp.
Did you install the whole mfl-pro suite? If not, do so. Check the installation by clicking installation check within the brother programm (start/progr./brother/installation check).
After a good installation press start/progr./brother. There you will find a pc-fax set-up. With that you can fax out of your pc thru the mfc.
If you want to receive fax on your pc you have to change settings within the machine . see handbook software which is part of the installation software cd how to do the right settings (chapter I 6 pc-fax)
Oct 13, 2007 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
601 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
