Question about Dayton 75,000 BTU Hot Dawg Heaters: Thermostat
Dayton 150,000 btu that won't stay lit
It is getting fuel, I cleaned the air filter, it sprays fuel and you can see the spark but won't lite
0 characters
1 Points
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one- Then Amazon Make sure it's the right one for your model heater.0810snp
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
The burner will not come on for our oil fired hot water tank and we are trouble shooting to get it going.
Oil filter and burner nozzle needs to be clean. Electrodes for ignition need to be spaced correctly and arc should be in line of fire when the inducer motor runs and bends the arc. Air intakes on for combustion air need to be set for correct combustion. Make sure your fuel has not coagulated from cold temperatures.
Jan 11, 2015 | Thermostats
What extent AC do I requirement to cool my chamber?
The regular is actually 3500 in order to four thousand Btu's associated with air conditioning have to make up for the quantity of temperature created with a one thousand watts lighting. Instance: ten By one thousand watts lamps will need among thirty-five, 000 as well as forty, 000 Btu's associated with air conditioning. Five By one thousand watts lamps will need among seventeen, five hundred as well as twenty, 000 Btu's associated with air conditioning. They are common recommendations because space circumstances, background air flow temps as well as air flow techniques almost all differ.
Oct 04, 2014 | Thermostats
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Apr 25, 2010 | Honeywell Programmable Thermostat Heater
Heat set for 72 and 62 degrees, running no heat only one year old what to do?
Need to know more information, like what kind of fuel you are burning, is it hot water or hot air, Is it doing anything? are ther any lights blinking? anything else you can tell us will help.
In the meantime, turn off the power and then turn it back on after a minute or so, it may get you going.
Jan 21, 2010 | Honeywell Programmable Thermostat Heater
Hot dawg garage heater circulating fan wont turn on.
it could be the sensor for the fan not working try jumping it out i take it tha *** lights up?
Jan 09, 2010 | Dayton 75,000 BTU Hot Dawg Heaters:...
Freeloader 300 pilot light goes out when I turn
make sure that the thermocouple is staying in the flame youmay want to replace it unless it is staing lit on its own until knob is turned if so gas valve bad
May 12, 2009 | Emerson Fans 300 Heating & Cooling...
I would check furnace filter first. If that looks good i would check the thermostat. To check thermostat turn power off to furnace then take thermostat off the wall and connect wires labbled R & W together then turn power on and check furnace to see if it runs for more than a couple of minutes. If so install a new thermostat. If that doesn't work let me know and i can give you a couple more thing to try.
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Thermostats Logo
Top Dayton Thermostats Experts
Dan Webster
Dan Webster
Ken Thomas
Are you a Dayton Thermostat Expert? Answer questions, earn points and help others
