Rca model p56812bl
No power supply working you can hear a pulse at fly back but no high voltage
  • marcelino solorzano Jan 23, 2008
  • 8,617 Answers
I would try soldering the flyback terminals on the PC board and also re solder around the Horizontal and vertical yoke pins as well as the transformer and line coils. Rca has ad some problems with bad solder problems on the circuit boards. let me know if I can assist you further.
Posted on Jan 23, 2008
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    Okay tomorrow i will give you some more areas to check.
Rca D52130
Power supply or high voltage supply problem---set well known for bad solder connections in and around the high voltage transformer---also known in early models for the high voltage splitter to be bad.
typical high voltage transformer:
Nov 05, 2012 | RCA Televison & Video
Screen pulses white. off and on, lite on front goes from green to red. model is Hisense TL2020
that problem is usually cause of shorted fly-back transformer that give a very high voltage you can find that by hanging all secondary connection of fly-back then power it again then use your multimeter and range it to dc then ground the black prove to the body of your unit test the b-plus voltage if the supply is flickering it means your fly-back is shorted and if the supply is stable it means you have a shorted diode in secondary thank you
Mar 05, 2011 | Hisense TL-3220 Television
When I turn the tv on it has no pic and then turns itself off but would come on after about 5 times of turning it back on but now it just had sound and no pic.
It seems that your Pulse Width Modulation drive ic on power supply or high voltage section fails. This can be resolve by replacing the IC MCZ3001d that will be found on your power supply or at the high voltage section.(near Fly back transformer) If you have basics knowledge in electronics and soldering, you can easily fix it.
Mar 02, 2011 | Sony KP-57WS520 57" Rear Projection...
RCA P56812BL, Flickering Static like lines
Check all inputs and tuner, that you can, and report back.
Apr 19, 2010 | RCA P56812BL 56" Rear Projection...
No audio/video
sounds like fly back failure. high voltage transformer
Aug 12, 2009 | RCA 27V514T 27" TV
Screen doesnt turn on then shuts power off
The fault you are describing is caused by a faulty fly back transformer. The fly back transformer provides the high voltage required to light up the picture tube/s on the set. Other than the fly back transformer there are a few components that supply the fly back with power that may have failed. Generally not overly expensive to fix
Jun 26, 2008 | RCA R52WH73 Projection Television
Sounds like the high voltage block,part number 205064,this part is behind the speaker grill,there is a access panel to remove,part is between the left and middle tube,has red wires from the tubes and black ground wires on the left side,hope this helps.
Jan 23, 2008 | RCA P56812BL 56" Rear Projection...
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
Powers on, audio works, no video at all
First, need to narrow down the problem. Did you perhaps change the input source? To this point, change the input source, there should be text on screen that indicates what source is you see this? Change the you see the volume level bar on the screen?
May 12, 2007 | Toshiba 61H70 61" Rear Projection...
No pic no sound just ticking
This set normally has problems in the horizontal and high voltage circuit. The horizontal output will short out and I often change the high voltage transformer. The high voltage splitter is another one of the usual suspects. Since it's ticking at plug in, then, I would look at the secondary of the high voltage transformer or the regulator circuit. Checking the the horizontal output first for a short and if ok, checking the B+ voltage on the collector would be my next step. That should give a good thought as which direction to go. Hope this helps.
Apr 01, 2007 | RCA P56812BL 56" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
