Hi, I use a Compaq V6608AU laptop. The issue here is with writing a DVD9. DVD ROM: Slimtype DVD A DS8AIP (supports DVD+R DL mode) Using imation 8.5 gb DVD+R DL to burn. Softwares: Nero and DVDfab Platinum ver: 4.0.5 I am able to write CDs or DVD5s with ease. I have tried to write a DL disc using both the softwares to no avail. After a few seconds, the softwares (DVDfab or Nero) stop responding (when I check in the task manager) and the dvd in the drive is rotates violently!! (sorry i do not know if there is a technical term for this). So, i end the process then manually eject the drive. Is this a firmware issue? can anyone help me with this... like i said I am facing an issue only with DVD9.
If the drive is violently rotating, and only doing it for these discs, it may not be able to handle them. This sounds like a product issue (not the software you are using as it funtions ok with past items. Your sytem may not support double layer discs.
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the...
(More)
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the underside to undo to find it.
Screen scrolls constantly in dialog boxes as an example of the problem. It seems like hitting any...
(More)
Screen scrolls constantly in dialog boxes as an example of the problem. It seems like hitting any key stops it. You can use the up and down arowws to move one line at a time. It starts scolling again at random.
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,...
(More)
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed, I hear the noise of opening mechanism, but the actual plate doesn't come out. Tried to open HP Solution Center, but got the following message: Parsing error in file C:Program filesHPDigital ImaginginhpqsclocC3.xml
I just bought an lg x10 and I´d like to use this equipment but my computer doesn´t...
(More)
I just bought an lg x10 and I´d like to use this equipment but my computer doesn´t see it. Could you help me? notbook lg x120 and crd-8520b/crd-8521b
