Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
Tv shuts off spontaneously. red power light blinks.
My 40" bravia about 2 years old shut off spontaneously in the middle of a program tonight. Red power light constantly blinks rhythmically 4 times. Tried unplugging and replugging. Gets power with sound, no picture for about 5 seconds then spontaneously shuts off again and the red power light begins to flash. Changed power bars. No effect. Is there a hardware problem? Something burned out inside? Expensive to fix?
  • 1 more comment
  • Rebbex Jan 23, 2008
    When I bought the $3000 Sony I didn't buy the extra warranty because it was a Sony after all. Live and learn.
  • Anonymous Jun 21, 2008
    while watching my sony bravia 40 inch went blany sound no picture
  • lizzysbs Jul 28, 2008
    As stated above, my sony lcd tv is about two years old and has gone black with the led power light blinking red four times over and over.  Any suggestions? Sony support referred me to our local Sears for a service call.
    Problem Solver:
Re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Posted on Aug 29, 2009
  • 43 Answers
Sounds like you may have a bad inverter board. This board powers the back light on the lcd panel. This board may be replaceable or the complete panel may need to be replaced. If the panel must be replaced you will be buying a new tv. Very expensive part. If the inverter is available seperatelly then it may be worth repairing. You should contact a Sony ASC for an estimate. Good Luck
Posted on Jan 23, 2008
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony bravia 40 inch red blinking light when turned on green light shows but go,s back two blinking red what should i do
you might try washing it.
submerge the tv in the bath tub, use lukewarm water only.
then turn it on.
problem solved.
Sep 13, 2014 | Sony Bravia KDL-40EX700 40" LCD HDTV -...
Sony bravia shuts off
A short circuit with its main board component, can make 8 blinks of standby/power light. These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 28, 2014 | Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My bravia will not stay on.
If Bravia tv wont stay On and shuts Off itself that means it got some internal problem, you will see red light flashing on tv front in specific blinking time that is an error code, let me know how many times that red light is blinking after three seconds long pause to diagnose problem.
Thanks.
Feb 08, 2011 | Sony Bravia KDL-46VL130 TV
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Oct 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
1,054 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
