Question about Siemens Gigaset 4200 Cordless Expansion Handset
Caller ID I set up caller ID w/ my phone company a couple days ago, but when I receive phone calls nothing comes up...How do I setup my phone so I can start seeing numbers come up when someone calls?
    Novelist:
  • 106 Answers
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
Jul 17, 2009 | Panasonic KX-T7636W Corded Phone
HAVING PROBLEM WITH CALLER ID WORKING
Go onto the menu of the handset and set caller id to on.
Mar 16, 2009 | ATS RA2180BB Cordless Expansion Handset
Caller ID
just go in the settings of ur phone and then phone setting or in contact setting
Jun 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Caller ID not working. It did work then one day nothing. Called phone company they checked and said nothing on their end. This is the KXTG5777ST base phone with 4 satellites. None of them have caller...
try entering *82 then followed by the number u are calling, for example : the number ur whom to call is 123456789 then u'll enter *82123456789 try that and if that works. go to urprovider to have it unblocked coz u have a blocked phone caller id. and note ur phone number will be show if it is emergency call....
glad 2 help...
May 04, 2008 | Lands Phones
Caller ID
Go to your setting and make sure the ID caller is on.
Apr 04, 2008 | Cell Phones
Cant get the talking caller Id
I lost the talking caller id after a thunderstorm. Can you tell me how to program it? I don't have a maual.
thank you.
Jan 13, 2008 | Sakar HT-848CL Corded Phone
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
Caller ID indicator
Caller ID indicator is probably a new call notification. You should be able to review the incoming calls list even if you do not have caller ID to stop the light from flashing.
Nov 24, 2005 | Panasonic KX TC1881B Cordless Phone...
Siemens Gigaset 4200 Cordless Expansion Handset Logo
3,089 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
