How to connevt visual basic with oracle(sql)
I dont't have idea to connect both of them.because of i have project on databse designing in 4th sem.so,i need your help.if possible plz help me.
    Problem Solver:
  • 8 Answers
First, you need to Install Oracle client software and make sure you are able to connect to the database (test the connection from SQL*Plus)
AMIRA FOODS INC
Posted on May 23, 2012
    Sergeant:
    Champion:
  • 244 Answers
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Posted on Jan 23, 2008
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
How to do vb.net framework ??
You need Visual Studio from Microsoft. Inside this visual Rapid Application Development (RAD) tools, you can use c++, c#, or basic language. It is lot of learning to become programmer.
You can find SharpDevelop free programing studio if you want to learn more. With this program, you will need .NET packages on your computer. It is like JAVA from Sun (Oracle). It is copy from Microsoft of JAVA ideas. Like free NetBeans IDE for JAVA development.
Inside studio you will have option for create New project. It can be grafical with graphical designer for draw some button, text input frame ... You will have properties for this objects, and possibility to write programming code. It is lot of learning to do real application. When you write some application you can compile it to exe output.
Visual Basic is only simplest part of this technology. C# (C-sharp) need more learning, and C++ is hardest thing.
Aug 26, 2011 | Computers & Internet
What is sql condition in visual basic?
sql is used for databases. Something like sql server, oracle, or access uses sql. It is a group of tables configured to reference eachother, so if you are programming in visual basic, you are trying to reference something on your sql server.
Feb 28, 2011 | Microsoft Xbox 360 Console
Visual Basic and SQL
Visual Basic 6.0 and MS Sql server 7 or 2000 are highly compatible with each other. VB.net is compatable with sql 2005 which is inbuilt as well.
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
Printing syntax
'declare the variables
Dim Connection
Dim ConnString
Dim Recordset
Dim SQL
'define the connection string, specify database driver
ConnString="DRIVER={SQL Server};SERVER=yourServername;UID=yourUsername;" & _
"PWD=yourPassword;DATABASE=yourDatabasename"
'declare the SQL statement that will query the database
SQL = "SELECT * FROM TABLE_NAME"
'create an instance of the ADO connection and recordset objects
Set Connection = Server.CreateObject("ADODB.Connection")
Set Recordset = Server.CreateObject("ADODB.Recordset")
'Open the connection to the database
Connection.Open ConnString
'Open the recordset object executing the SQL statement and return records
Recordset.Open SQL,Connection
'first of all determine whether there are any records
If Recordset.EOF Then
Response.Write("No records returned.")
Else
'if there are records then loop through the fields
Do While NOT Recordset.Eof
Response.write Recordset("FIRST_FIELD_NAME")
Response.write Recordset("SECOND_FIELD_NAME")
Response.write Recordset("THIRD_FIELD_NAME")
Response.write "<br>"
Recordset.MoveNext
Loop
End If
'close the connection and recordset objects to free up resources
Recordset.Close
Set Recordset=nothing
Connection.Close
Set Connection=nothing
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
I want connet foxpro databse to visiual basic
Using a DSN-less connection to open a free table
cn.Connect = "SourceType=DBF;" _
& "SourceDB=C:\Vfp\Samples\Data;" _
& "Driver={Microsoft Visual FoxPro Driver}"
Jan 20, 2009 | Computers & Internet
Need a banking project on visual basic
go to following site : http://www.programmer2programmer.net/live_projects/project_1/ebilling_invoice_system.aspx
download ebilling project.
Good Day
Dec 11, 2008 | Microsoft Step by Step Visual Basic 6.0...
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Connection of Oracle9i with Visual Basic 6
if oracle scott
password tiger
if not acccepted go to control panel ,administrative services put
oracle services manually & start it.
ur's kishore chowdary.(+919441133420)
Mar 28, 2008 | Computers & Internet
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
Computers & Internet Logo
212 people viewed this question
Alun Cox
David Payne
David Payne
