Question about E-Machines eMachines Desktop PC
I have a emachine t2862
And i unhooked the cords to take the front off the computer the onesthat allow me to push the power button and it turn on the cordsplugs say pwr lew and pwr s/w and hdd led and i dono how to put themback and i need to know in what order they go in
    Genius:
  • 1,067 Answers
Is it 12 pins should say pw meens main power sideways acros set red in p then over one never up and down then go to r for reset do that one 2 pins then oiver to next one to u see it start up then idd pled so on
Posted on Jan 23, 2008
No power when I turn on my T2862. Changed the power supply, still no good. any ideas?
You can try tracing back the wires from the power button on the front panel to the motherboard, look at the prongs it is plugged into. Pull off the power button wires, and use a screwdriver to make contact with the prongs the power button was plugged into. This is a way to bypass the power button switch to eliminate it as a cause for not starting up.
Oct 21, 2010 | E-Machines T2862 PC Desktop
EMachine T2862 has no sound
If your computer does indeed have a Sound Card, then the drivers for this card are not working. Try reinstalling from the driver disk you got with your computer and see if the sound comes back.
Nov 01, 2009 | Computers & Internet
T2862 wont work -no power goes to it.
emachine?
is it new?
if its not, then check the power supply, there should be a green light on the back of the unit. if this is yellow or not lit at all then the problem is your PSU
crack the case and make sure the PSU cables are connected properly
also while your in there check for swollen capacitors or dust
Sep 04, 2009 | E-Machines eMachines Desktop PC
We have a emachine w2060 and my mother unhooked 3 small cords looking for a power problem the small green and white the small red and white and the small black and white? i dont know where they belong so...
Unfortunately eMachine manuals are not very thorough. Here is a link to the support page for your computer:
w2060 Support
At the bottom of the page is a support telephone number. Call and explain that you need the front panel pinout for your computer. That's what it sounds like you have disconnected. There is also a link for online chat if that is an option.
I did find this page eMachine Pinouts that may be of help to you. It does not give the colors of the wires, but look for the abbreviations on the connectors such as HDD, PWR, and PWR LED.
May 12, 2009 | Computers & Internet
Emachine T2862
have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Feb 01, 2009 | E-Machines eMachines Desktop PC
Emachine t2742 I also have a wiring problem!
gtater,
It's ironic that you ask me this question today-- i am just now carrying in another eMachine computer to fix. Anyway, unfortunately I do not have one that is the same model as yours (T2742). However, I did some quick research and found that yours has the same exact motherboard as the T2898 which I made the diagram for!
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
For further reference, I would like to share this diagram for the eMachines T6544 in case someone else may need this model. This is the computer I just carried in... might as well share.
By the way, the power switch doesn't need to be oriented any particular way (positive and negative), which is why the switches are not labeled as + or -. Switches can be wired either way and they will work the same.
Hope this helps.
Jan 03, 2009 | E-Machines eMachines Desktop PC
T1150 emachine Computer not booting up correctly
did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Nov 29, 2008 | E-Machines T1150 PC Desktop
Front panel leads Emachine model T2862
E-machine model T2862 pin-out for the 10-pin front panel header is screen-printed on my Emachine's motherboard, but is so small and far away from the actual pin location, that it is likely being overlooked. If looking into the computer case from the side where you remove the panel, the header looks like a row of four pins with one missing at the farthest right pin location, and a row of 5 pins underneath that, with the fifth pin directly below the missing (key) pin in the row above it. Starting on the first row, you would install the 2-pin connector from the front panel labeled "Power LED" to the leftmost and 2nd from the left pins. (You may need to switch it around to get it to work as the LED is polarized. You will know as soon as the system starts to boot up if it is on properly, as this light burns constantly if the unit is on.) Then, to the right of that connection, you would connect the 2-pin connector labeled "Power Switch" to the 3rd and 4th pins from the left on the first row. (It does not matter which way around this connector plugs on, as all we are really doing is allowing the front panel button to connect these pins together to turn the system's power supply on when you press the button.) OK! Drop down to the BOTTOM row of pins below the first row. To the leftmost and 2nd from the left pins on the second row you will install the connector labeled "HDD LED". (Again, you may have to switch it around to get it to work since it is polarized. You will have to watch the system boot up and as the hard drive is accessed, you will see it blinking randomly if it is connected properly. NOTE: You will not damage anything if this or the power LED is hooked up wrong. They simply will not function. So don't fret, just switch them around.) Next, the header has room to connect a reset switch if your system has one. (Mine does not.) You would install the 2-pin connector labeled "RESET" to the 3rd and 4th pins from the left on the second row of pins. (Again, this is a connector that works fine regardless of which way around you install it, as it simply lets the reset button connect these pins to reset the system when the button is pressed.) Finally, you will notice one pin is left unused below the missing (KEY) pin. As far as I know, this pin does nothing, but is likely a ground or maybe a source for DC power as I have seen before. The unused pin above it is for manufacturers who make one connector coming from the front of the case which is pre-wired with all these functions, so the connector (usually with 10 total possible wire locations) can have that one location sealed or capped to prevent someone from installing it the wrong way around and potentially sending voltages somewhere they shouldn't be going, or causing something to not work properly. I made a quick pic in MS Paint below for better reference:
May 23, 2008 | Computers & Internet
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
100 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
