Question about Philips 50PP9202 50" Rear Projection Television
Philips 50PP920217F remote/color
Ok, i just got this TV as a gift.... the colour is off on it and i saw something about colour convergance..... ya, so i tried hitting the menu button on the remote. it does not pull up anything.
i am wondering if there are any shortcut keys or buttons? any other way to make the tv work short of spending a bundle on it?
any tips?
BTW, the picture kinda looks 3D. red in one place, blue just below that, ect....
Thanks for the help
  • 2 more comments
  • Anonymous Feb 13, 2008
    Our color is off also....there seems to duplicate images due to red and green colors both showing slightly above or below each other. I also tried using the remote control to try and adjust but it doesn't do anything.
  • jmserranos Feb 19, 2008
    i have the same problem!
  • Anonymous Nov 10, 2008
    Picture has a 3d look to it. Whats going on?
  • tcunniff Jan 10, 2009
    I have the same problem. It just appeared yesterday.  The center of the screen is fine but the colors seperate or double images on the right or left side of the screen.
Whats next after IC's replacing?
Posted on Mar 10, 2008
  • jmserranos Mar 10, 2008
  • jmserranos Mar 11, 2008
    all resistors were ok, now after a couple of hours and 20 bucks cost TV is working fine, thanks terryfic
  • 1,694 Answers
Requires convergence amp IC replacement ( two) and check
resistors in vicinity of IC's....fairly technical repair....Please read
some of my convergence solutions and let me know if you want
step by step instructions............................T.
Posted on Mar 06, 2008
  • Vista Electronics Mar 11, 2008
    Did you check resistors around IC's for over-heating and / or
    changed value ? it up & see what u get.................T.
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
PDF download of your Owners' manual:
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
46" projection tv ..colours were
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc
Dec 16, 2010 | Philips 46PP9302 46" Rear Projection...
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
The colors on our tv are slightly misaligned. I'd
hello i would order a remote first if the colours do not relign then it could be the convergance chips may be the problem good luck
Aug 06, 2009 | Philips 60PP9352 60" Rear Projection...
Colour convergence on a projection TV
hello it sound like convergance chips may be the problem
May 11, 2009 | Philips 43P8341 43" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
because you have defective convergence correction circuit amplifier! the only thing you can do now is to replace the convergence IC.
Oct 21, 2007 | Philips Magnavox 27MS343S 27" TV
Colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Jun 10, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 50PP9202 50" Rear Projection Television Logo
359 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
