Question about Linksys Wireless-G WRT54G Router
My laptop won't work wireless
I installed the wireless-G WRT54G on my laptop , now whenever I disconnect the wire from my laptop that's connected to the router, after I made it wireless I have no internet connection. What do I have to do to make my laptop work wireless with the router. I do have the router connected with a cabel modem.
  • Pascal Willemen
    Pascal Willemen May 11, 2010
    What type of laptop do you have? And what brand is it?
    Greetings,
    DarkNeogen
    President:
  • 2,351 Answers
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Posted on Jan 24, 2008
Whenever I connect the router it says no internet access....
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
May 21, 2011 | Linksys Wireless-G WRT54G Router
Router will not work wireless after switch from DSL to cable
You can go to 192.168.1.1
Enter the default username(leave it blank) and password(admin) and enter the router page
Under setup--> basic setup you can configure your ISP settings
Under wireless you can configure wireless username password etc
If still unable to connect wireless mention the operating system
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
Lost wireless router CD
You can make the router working even without using the CD. Who is your ISP? Are you having concern with wired or wireless connection?
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Linksys wrt54g with sony vaio webcam won't work
check the LAN cable from the internet connection going to router.make a sure that wire is OK.if the wire connection is a ok go to your PC/unit then make sure the Lancard/wire less lancard driver is complete or remove the Old lan/wieless lan drivers and install a new or update the drivers.good luck and have a nice day
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G not seeing internet connection
spacer335,
Who is your Internet service provider, and do you have cable or DSL? You said you have your PC, Xbox and DVR all hard-wired and working fine; are they currently able to get online while connected directly to the Linksys WRT54G? What devices are you trying to connect wirelessly to your Linksys WRT54G?
If you are currently getting Internet access let's check the wireless settings in your router.
Here are a few things you can do to verify your wireless settings in the Linksys WRT54G:
1. From your hard-wired PC, log into your Linksys WRT54G via the web-based interface. (Open Internet explorer and type 192.168.1.1) Note: this is the default IP address that comes on most Linksys routers.
If that doesn't work, verify your computers current IP address information by going to Start (or in Vista it's simply a windows icon), and selecting Run. Type CMD and hit Ok. Now type ipconfig and hit enter.
The default gateway information is the address of your router and should read something like 192.168.1.x.
Enter that address in Internet Explorer's address bar and hit Go.
2. If you connected successfully you should receive a username and password prompt, again the default username and password that comes with most Linksys devices is admin/admin, however it could be different if you've specified an alternate username/password. If you cannot remember the username/password, your only recourse is to perform a hard-reset of the device by using a small pin and holding the reset button on the back of the router.
3. Once you're in the router's web-based configuration there will be a section for "Wireless Settings" or "Wireless Configuration", or some derrevation. Depending on the version of firmware you have installed on the unit, it may be under Basic Setup or Advanced Setup.
You'll know you've located it when you have see options for SSID, Channel, Wireless Security/Encryption, WEP, WPA, etc.
This section will tell you the name of the signal your router broadcasts (also known as SSID). You can change this to whatever you like, in fact is reccommended you change to something unique so that you can easily identify your network when trying to connect with a laptop. You can also enable wireless security such as WEP or WPA, however for the purposes of troubleshooting let's leave encryption off for now. Once you've made the neccessary changes, select Save or Apply at the bottom of the page to save your changes.
4. Now, again since I don't know what you're attempting to connect wireless I will assume its a laptop with an intergrated wireless adpater, or possibly a USB or PCMCIA wireless adapter. Either way you should see your network (with the new name you've configured) in the list of avialable networks, do you see any networks listed? If the laptop has built-in wireless, is the WLAN switch enabled on the laptop? (Usually a small switch on the front or the side of the laptop indicating WLAN, or sometimes a function/fn key combination)
Hope this helps somewhat, give me some more information about what you're trying to connect wirelessly with and I'll see if I can help you out.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Wireless router disconnects every 5 minutes...
I had the same problem with my dlink (not wireless). Try going to their website and configure the router. It worked to me.
Dec 07, 2007 | Linksys Wireless-G WRT54G Router
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
