Question about Toshiba 43H70 43" Rear Projection Television
Powers up no pic
It power`s up the crt`s are lit but no hight voltage, but when i tap the chasses the high voltage comes on and pic is jumpey like a vert proublem
need help
  • Rob McCutcheon
    Rob McCutcheon Feb 02, 2008
    THANKS SO VERY MUCH
  • Rob McCutcheon
    Rob McCutcheon Feb 07, 2008
    hello were is the vertical yoke pins.?
  • Toshiba Master
  • 8,617 Answers
You have a bad solder connection in the Vertical deflection circuit. Try re-soldering the vertical output IC and the Vertical yoke pins. You may have to look over the Vertical circuits with a magnifying glass to actually find the bad solder . A hint if the solder looks dull re-solder it.
Posted on Jan 23, 2008
  • Sonny Berry
    Sonny Berry Feb 10, 2008
    trace the wires from the yoke on theCRTs back to where they plug into the chassis. There will be 6 plugs 3 horizontal yoke plugs and 3 vertical yoke plugs. Horizontal are usually larger plugs where as the vertical are smaller.
Supplied output voltage has hight frequency
Line-load-regulation to the TV power supply board is very low. Replace the main power supply board.
Jan 24, 2013 | Televison & Video
How to replace power supply
unscrew the screws on the back and open the chass. then draw a map about the connections where those power cables went into inside the chass. then unplug all the power connections and unscrew the screws on the back which fasten the power supply to the chass. remove other components if necessary to alow space for the power to come out. then replace the power and anything else in reverse order and reconnect the power cables according to the map.
Mar 02, 2012 | Acer L410G PHM19 3GB 160GBDVDR X1250...
No power
Check ur power source,might need FBT,flyback transformer,the big plastic block with a red wire with a cap hook to a CRT(tv tube).Hight voltage.
Oct 07, 2009 | Samsung CW29M64NS 29" TV
No raster, no audio, CRT filaments lit, 20KV high voltage, B+ 136V.
most likely you are missing one of the scan derived power sources; most of these sets when HV is present produce some secondary voltages for other things---look at diodes and resistors around the flyback (HV) transformer--if you find an open resistor there--follow it back to the diode that supplies it---also try to check all the smaller voltages from the main power supply
Aug 07, 2009 | Disney DT1900-P 19" TV
When you plug in the tv the tv appears to come on and you here a click. The timer light stays lit red and the screen will not come on.
There is a fault in your tv, if this is a crt type could be at high voltage section.HOT is shorted , flyback is shorted or both. But atleast your standby power is working. The click sound could be the relay in action.
Mar 04, 2009 | Samsung PCL5415R TV
NO HIGHT VOLTAGE
sounds like the LSB is defective as that controls all the high voltage and deflection circuits. If you go to the following link and leave them a email with your model number they should have a LSB board for your model.
http://servicemanuals.vstore.ca/
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Help
resolder the vertical IC that is whats making the CRTs go blank. Its a safety issue where the CRTs blank when there is no vertical deflection. Just resolder the output IC that should cure your problem
Mar 12, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 43hx70
i dought it, check aroiund the convergence ic's "stk392-xxx"
Feb 08, 2008 | Toshiba 43HX70 43" Rear Projection...
Volume buttons stuck inside
hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
May 06, 2007 | Sanyo DS24425 24" TV
Panasonic CT-27SC14
The high voltage should be around 29.5 KV and not fuctuate between 20-30 KV that would indicate a high voltage regulation issue then. Are the filaments lighted up in the neck of the CRT? If so then yes you are probably looking at a low voltage issue such as a 12 volt source or a a/v switching IC issue.
Apr 23, 2007 | Panasonic CT-27SC14 27" TV
Toshiba 43H70 43" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
