Question about E-Machines eMachines Desktop PC
Identity of front panel wiring
What is the identity of front cables/ wiring emachines model t2865
    Genius:
  • 1,067 Answers
What u meen front out in mic in headphone out ? or u meen the wires to plug into mobo
Posted on Jan 23, 2008
I need an illistrated guide to show me where to connect all hardware connection cables to the t2865 motherboard
http://www.retrevo.com/support/eMachines-T2865-Desktops-manual/id/14680ci368/t/2/
Jan 28, 2014 | Computers & Internet
T2865 chipset series
Which one is on the manfacturers site for your computers make and model?
Get onlineand got to www.google.com In the google search box type: "EmachineSupport" or "Gateway Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.If the site shows more than one, use the one with the latest date.
Apr 30, 2012 | eMachines Computers & Internet
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Hello all: emachine T3882 wiring diagram
Look very closely at the motherboard where the wires go... maybe with a magnifying glass . should say what wires go where. ie. (hdd led,reset, pwr. etc) if you reverse the wires.. just switch them back. its just for indicators.. also u could google the mainboard model number or search acer site for led pinout on mainboard.
Dec 16, 2009 | E-Machines eMachines T3830 PC Desktop
Specs and pictures for a t2865 emachine computer
ok, you may look the motherboard manual:
1) set USB from page 14
2) set the front panel four connectors look from page 12
the manual reference :
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
hope help you fix it.
May 15, 2009 | E-Machines eMachines Desktop PC
Need owners manual
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2865
Mar 05, 2009 | E-Machines T2865 PC Desktop
Connect wires to the motherboard
Please tell me the model number then I will be able to help you.
Nov 14, 2008 | E-Machines eMachines Desktop PC
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Apr 19, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
Emachines t2865
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Feb 17, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
