Question about Baby Gear
Cadillac heater blower replacement
1996 Cadillac DeVille Concurs. The blower fan for defrost, defog and heat to the passanger compartment Gave up the ghost last week just before the weather turned cold.
How do you remove the blower fan?
I see that tech bulletin 631104 2/96 has a revised heater installation procedure but where can I find a copy?
  • 50 Answers
It should come out from under the glovebox
Posted on Jan 25, 2008
I have a 93 Cadillac Deville when I turn on the heat it blows a 10 amp fuse and the transmission stops changing gears. What is wrong?
4504204 A/c blows fuses - Document Download
thebestsolutions.top/F/cars/t4504204-c_blows_fuses
4504204 a/c blows fuses ive had feron checked replaced a/c relay fuse last about 10 ... I have a 2006 impala that is blowing the 10 amp fuse to the ac/compressor/a new will last ... 93 corolla 1.8 No start Blown ignition fuse ... i have a cadillac deville the a c blows hot air on ... air con fuses air con heating mk3 mondeo talkford.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
I have a 1996 Cadillac DeVille that the blower motor stays on unless you unplug it. ... +mgittelman hi mate ...
Cadillac Repair - Questions and Answers from October 12 ...
en.allexperts.com > Shopping > Vintage Cars
Nov 3, 2006 - 91 Fleetwood "check engine" light, 10/31/2006, Tom Joy ... Q: My 95 Deville blows air when the heat is on, but the air never warms. ... 96 Deville Interrior Lights Inoperative & 3.2 Amp Draw on Body Fuse 3. ... Q: I have the 93 cadillac deville and those codes came up right after a transmission replace.
Cadillac Seville Questions - Heating/AC fan runs when car ...
Jan 10, 2016 | 1993 Cadillac DeVille
Have a 1996 buick park avenue heater works only on half the car passanger side has heat driver side cool air the defrost to vent to floor doesent work check for vacume to heater switch no vacume at all...
you can have relay fan faulty, blower, or heating elements or duct NOT o.k .However you can go to www. aa1car.com get the topic and fix it.
God bless you
Nov 20, 2013 | 1998 Oldsmobile Intrigue
1998 Cadillac Deville Heater blows cool, Semi-warm at any setting ( except low, Air does work )
THERE IS A RELAY CONNECTOR THAT GOES TO THE BLOWER AND THAT CAN BE REPLACE AND THAT WILL PICK UP ALL 1234 SPEEDS THEY ALWAYS TEND TO GO OUT IN TIME
Jan 15, 2013 | 1996 Cadillac DeVille
'94 Cadillac DeVille Concourse. My winsdhield
Follow the wires from the blower motor back to the blower motor resistor, normally only a few inches away and held in by a 7 mm screw. Replace it
May 13, 2010 | 1998 Cadillac DeVille
Hello my friend has a 1995 deville that wont heat. He thought the blower was bad so we put a different on it and wired it to run with the key on. It runs but will not blow air into the car. None of the...
If the blower was working why did you replace it?
Heat is made by the engine, and then it is sent into the heater core and a fan, blower motor, blows heat into the car.
First - check that the coolant level is full. If not add MIXED coolant.
Then drive a few miles for the engine to get hot.
If coolant level is full, the thermostat might be bad, or the heater core might be plugged.
Dec 15, 2009 | 1995 Cadillac DeVille
I have a 96 deville. have replaced the blower
INADVERT Relay next to the engine compartment fuse block on drivers side i need one to
Aug 13, 2009 | 1996 Cadillac DeVille
'96 cadillac deville has no air.cond./heat
Unfortunately for you ( i had the same problem) The A/C compressor HAS to be in working order on these cars or else all heck breaks out with the climate control.
If it's a nice car, get a new compressor installed. If it's borderline- get rid of the car.
I paid 2200 to Cadillac to fix the A/C and climate control only to have the transmission fail in my '93.
I dumped the car soon thereafter....
May 27, 2009 | 1996 Cadillac DeVille
A/c fan and blower
it is prob. the a\c/heater blower. yes they are very different
Apr 21, 2009 | 1996 Cadillac DeVille
No blower/fan at any time car running or not.
check fuse. if ok. replace blower motor.
Feb 24, 2009 | 1995 Cadillac DeVille
1991 cadillac deville NO HEAT
I had the same problem in my 1991 caddy, and turned out to be the blend door. It is located in back of the glove compartment. There are two kinds, the automatic blend doors and the manuel ones. Since the temperature is automatic and programmed to stay where it is set, it would be an "automatic blend door". Not a hard fix...
Oct 18, 2008 | 1991 Cadillac DeVille
Baby Gear Logo
108 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
