Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Solobaric subs l7 15-inch
How do wire my subs 'two 4-ohm l7's subs, mono amp: 2-ohm load
  • Anonymous Mar 29, 2014
    Ohm for 8 inch sub
    New Friend:
  • 101 Answers
This should help you
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Posted on Jan 23, 2008
    Problem Solver:
  • 7 Answers
When you drop the Ohms and put them together, they go even lower. 2ohm + 2ohm = 1ohm which ur amp is not capable of. try this, with one subwoofer on one voice coil connect the positive (+) and negative(-) together(the ones without the dots) and the ones with the dots run to the speaker terminal like normal. do this for both speakers
<a rel='nofollow' href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=2_4ohmDVC_1ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/2_4ohmDVC_1ohm.jpg" border="0" alt="Photobucket"></a>
this is what you did...
<a rel='nofollow' href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=1_4ohmDVC_8ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/1_4ohmDVC_8ohm.jpg" border="0" alt="Photobucket"></a>
this is what you want...
Posted on Feb 12, 2008
  • sepsi
    sepsi Feb 12, 2008
    sorry....this is the way you want to wire the subs
    [IMGhttp://i14.photobucket.com/albums/a312/k...[/IMG]
  • sepsi
    sepsi Feb 12, 2008
    when you drop the Ohms and put them together, they go even lower. 2ohm + 2ohm = 1ohm which ur amp is not capable of. try this, with one subwoofer on one voice coil connect the positive (+) and negative(-) together(the ones without the dots) and the ones with the dots run to the speaker terminal like normal. do this for both speakers
    this is what you want....
  • 65 Answers
Like this. Go to this link for a diagram:
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Please leave good feedback.
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Tip
How to wire subwoofers correctly.
If you're ever unsure about how you need to wire your subwoofers to get the correct ohm load to your amplifier there are a few resources to help. Usually in the owners manual that comes with your subs and your amp they include a detailed ohm load calculator. First step is to determine what subwoofers you have. Common subs come in a dual 2 ohm or a dual 4 ohm version or a single 2 ohm or a single 4 ohm version. Next determine what ohm load your amplifier is rated at. Mono "subwoofer" amps usually are rated x amount of watts at either a 2 or a 1 ohm load. This means you need to purchase the correct subwoofer combination to match your amp. If youre purchasing 2 dual voice coil 4 ohm subs then to maximize an amp you should buy a mono amp stable at 1 ohm. and Dual 2 ohm subs would need a 2 ohm stable amp wired in series parallel. A great resource for a beginner is to go to www.the12volt.com and on the top of the page find the words "subwoofer wiring diagram" and click on it. This will bring you to a drop down menu where you choose the number of drivers "subs" or "speakers" you have and then you choose the impedence in the next drop down menu. Next you'll be provided with multiple wiring options. Good luck and never think you can't do it yourself. Once you learn it's very easy to retain.
on May 31, 2010 | Car Audio & Video
I have an old school autotec xs 1500.1 and need to know how to hook up the outs to make it 1 ohm
Since it is a mono block amp, it depends on your subwoofer (s), and how you wire them to the amp.
Single 4 ohm sub would be just that, 4 ohms.
Single dvc 4 ohm sub, with both voice coils wired parallel would be 2 ohms.
2 dvc 4 ohm subs wired parallel would be a 1 ohm load.
Feb 20, 2015 | Ohm Car Audio & Video
I need to hook up two audiobahn A1200Q subs to a A1300hcq amp
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 17, 2009 | AudioBahn Car Audio & Video
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
I have a ly1440 amp how can i wire it to my hk15x2
This subwoofer has (2) 2 Ohm voicecoils.
Which means you will only be able to wire a 1 Ohm or 4 Ohm configuration for your amplifier.
The Model # you listed for the amplifier is not a valid one.
If your amplifier is 1 Ohm mono stable...
you wire both (+) Sub to amp (+)
and both (-) on Sub to amp (-)
This is PARALLEL wiring and lets the amplifier SEE a one ohm load
If your amplifier is NOT one ohm mono capable - your only other possibility is a 4 Ohm load.
Wire from (+) on amplifier to one (+) on the sub
Then Wire from (-) on amplifier to the OTHER terminal's (-)
You will have one (+) and one (-) left on the subwoofer - wire them together.
This is SERIES wiring, and nets a 4 ohm load for your amplifier.
There is no other configuration for wiring one Dual 2 ohm sub.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 07, 2009 | MA Audio HK15X2 Car Subwoofer
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Wiring options for amp
Te dual inputsm are tied together on the output side thus having a "MONO" amp. Most class D anps are stable down to 1 ohm (check your manuel) therefore, 2 2ohm subs are a 1 ohm load. 2 DVC (dual voice coil) 4 Ohm on each voice coil will give each sub a 2 ohm load so 2 dual4 ohm V's will give you a 1 ohm load as well. Parrallel all conections.
What subs do you have? Is this amp 1 ohm ono stable?
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 09, 2008 | Car Audio & Video
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
682 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
