Kenmore Quiet9 Washing Machine
My machine keeps getting stuck and sending an F 02 error message. I am unsure what this error means or how to fix this problem. Please let me know if you are able to help with this matter.
Thanks in advance,
Jennifer Baker
  • 447 Answers
This means that the washer isnt draining. More than likely the drain pump has a sock or who knows what in it. Very common. To axcess pump you remove front service panel
This repair is definatly something you can do yourself.
Remove 3 torx or 7mm screws under front panel (between pedestal and washer......if its on a pedestal that is.
Now comes the messy part....Have a Wet Vac handy and remove all the water you can through the door.
Now start unscrewing the brownish plastic Clean Out housing sucking up water with vac
once water is done remove clean out and see whats in there. If there is nothing in there than you may need a new pump and they are not cheap! Let me know what you find.
Posted on Jan 23, 2008
6ya staff
SOURCE:
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Keeps getting fl error message
    Search Results
      Why am I getting an FL error code on a Kenmore Calypso ...
      www.shopyourway.com > Manage My Life > Questions
      I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    Jan 27, 2016 | Washing Machines
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    5d error code kenmore he2plus
    Here's a video prem mathew suggested as a solution to your problem from YouTube:
    Kenmore He2 washing machine washer drain problem fixed
    Apr 26, 2013 | Kenmore Washing Machines
    Kenmore washing machine 110.22082 does not drain
    you probably looking for a new drain pump ( control board also possible)
    Sep 05, 2009 | Washing Machines
    Kenmore he2+Will not go through clean machine cycle
    Open bottom panel, there should be a tech manual, see what the error message means.
    Mar 01, 2009 | Kenmore 46462 Front Load Washer
    Kenmore Elite Washing machine error codes
    I am getting F35 error code. What is the problem?
    Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing machine keeps stopping
    E20 not draining error. Since you checked filter at bottom right corner for blockages, then maybe the drain pump has gone faulty or something jammed in it. You can also check the drain hose for kinks or blockages. You can try blowing out any cloggs in the machine with an air compressor.
    Please let me know if you need any further help, otherwise good luck on fixing your problem.
    Apr 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    I get a F error message when the cycle is one minute into the start....
    I DON'T KNOW BUT IT SEEMS I HAVE HAD NOTHING BUT PROBLEMS WITH THIS WASHING MACHINE. MINE IS NOW STUCK CLOSED WITH ALL MY SONS JEANS IN THERE, AND NOW I HAVE THE F CODE TOO!.
    Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
    No Spin
    Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
    Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Washing Machines Logo
    55 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
