Motherboard manual ?
Where can i fine amnual for an old foxconn motherboard ? it has a pentiun 2 slot ,3 memory slots , 3 pci slots ,1agp slot . On the side of the AGP slot it says FOXCONN, and has a sticker on it that says p7s8c020508. It has a brass colored chip that says PC 100 BX 1000 another chip says SIS 6326 agp , 686 amibios 1995 american megatrends CW4 1381 .The bottom of the board has 98 1208 engraved on it .....can`t boot the computer to find any other info thanks
  • Umesh Kumar Dave Feb 25, 2009
    I want know. wich side north in morthboards
I need the power configuration settings for dell p 3 mother boards
Posted on Oct 25, 2009
  • 1,067 Answers
Is jumpers on 1 and 2 good power test ram front conecter on pw
Posted on Jan 25, 2008
  • nick helpap
    nick helpap Jan 26, 2008
    can u use xp disk boot into that formattt it
  • nick helpap
    nick helpap Jan 27, 2008 has your maneul if u loook change the rating also
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
What are the three expansion bus slots that are found on the mainboard?
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16) (Note 4)
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8) (Note 4)
  3. 3 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
(Note 1) Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connector by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When PCIEX8 is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
(Note 5) Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
(Note 6) Available functions in EasyTune may differ by motherboard model.
Feb 23, 2011 | Gigabyte GA890GPAUD3H AM3 Socket 890GX ...
How frecquecy it must to have from RAM ? how nvidia it is OK from mpga478b ?
The Foxconn K8S755A6ELRS motherboard uses DDR Sdram at a frequency rate of either,
266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
The Maximum Total Amount for the motherboard is 3GigaByte (3GB)
There are 3 Ram Memory slots.
The Maximum Amount for EACH Ram memory slot is 1GB.
{Has an AGP expansion slot for a graphics card.
Uses AGP 8X graphics cards}
Under the Related Links heading to the upper right, the;
A) Motherboard manual
B) Drivers
C) BIOS update
D) Sample of the manual for disassembling is listed.
(Among other things)
Dec 10, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
I have a Foxconn Motherboard. UYD8513801460PC661MO5-MX-6LS. Memory is DDM256MBDDR. I want to upgrade to 2GB how many pins should the memory card have. A F Edgecombe
check ur motherboard manual how much RAM it can support, guess it will have 2 slots for RAM so u can have 2 RAM cards of 1mb each...
ur motherboard manual will tell u the pins the rams should have...
DDR pins are of 184
Dec 14, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Is the AGP a 2x or 4x?
Its niether..
xpansion Slots PCI Express x16 1 PCI Express x1 1 PCI Slots 2
Sep 26, 2009 | Foxconn 6150BK8MC-KRSH Motherboard
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
What i have as agp or pci and whats the best graphics card i can get without getting a new pc
An AGP video card would provide a better video performance than a PCI video card.
Jun 06, 2008 | Foxconn (865G7MC-ES) Motherboard
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Upgrade to graphics
your in luck you have 2 options 1.use a agp graphics card 2. use a pci graphics card depending on how much money you want to spend,personally i would use the agp but it's up to you.You have 1 agp slot and 3 pci slots,an agp slot is brown and smaller than the white pci slot.You can use a top of the line agp i would get a nvidia agp gforce 3 or better their 80 dollars and upward
Oct 06, 2007 | Computers & Internet
Computers & Internet Logo
1,329 people viewed this question
David Payne
David Payne
