Question about Yamaha HTR-6030 Receiver
No component video output
I have plugged in my SONY DVD player to the Yamaha HTR-6030 receiver via the component video input. I am using the component video out to my TV.
This has been working for the last couple of weeks, but after attempting to add my Satellite receiver to the mix, I now have no video output. I have plugged everything in directly to the TV to verify that the problem is indeed with the receivers monitor output. Any ideas?
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Posted on Feb 28, 2008
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
I have no TV box but do have cable, how do I hook up TV,VCR,DVD, and YAMAHA HTR 6030
For watching TV, your TV should have a monitor out. This will go to your CBL/Sat input on the receiver. If you have a newer TV, it will have an optical output,if you use that, you will have Dolby Digital surround when available, and digital stereo at all other times. For the VCR and DVD, if they are separate units, Run audio video from the VCR to the receiver to VCR 1, for the DVD, use Component video and optical or digital coaxial to the receiver. Then from the receiver run component video to the TV. If you need further help, post a comment and I will help you further. Hope this helps
Dec 28, 2009 | Yamaha HTR-6030 Receiver
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Setting up DVR, Receiver & VCR w/out cable box
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Sep 26, 2009 | Yamaha HTR-6030 Receiver
No sound from my htr-6030 when i hook it up to my dvd player with
If you can't use one of the Optical Digital Audio INPUTs on the HTR-6030, why don't you just use the Analog Audio Out on the HDD and an Analog Audio IN on the HTR-6030? It has one actually marked 'DVR', but any one would do.
Mar 19, 2009 | Yamaha HTR-6030 Receiver
Hooking up multiple components to HTR 6030
Once you have installed all the cables to the system, you will need to go in to the Yamaha's system settings (see owner's manual) and assign the audio inputs accordingly. The DVD input will need to be set to the optical input # you have selected. Optical and digital coax are not preset in most cases. Once you get to the input selection assign the digital # for DVD and then exit out. You should begin to hear the audio immediately. If not you missed a step. I do this for a living and every unit has its own routine you need to learn.  Enjoy the system Rob
Feb 27, 2009 | Yamaha HTR-6130 Receiver
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR-6030 Receiver Logo
466 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
