Intermittent spin cycle on Kenmore 90 Series washer
The spin cycle is intermittent on a 10 year old Kenmore 90 Series Washer with model number 110.26934691. I've already replaced the clutch, the timer and by pass the lid switch. The spin clycle is still intermittent. When the spin cycle does not work: It drains fine with the baket on low spin. Then the basket gets to a higher spin. The basket stops, the timer and motor continue to run through the spray cycle to off, leaving the laundry wet. No spin. Thanks for your help.
  • 2 more comments
  • Ken90 Jan 24, 2008
    It is not the speed selector switch. I just tested the switch by placing the speed dial on delicate (slow/slow) and the timer to spin. The basket spins. While the baket is spinning I turned the speed dial to regular (slow/fast) and the basket spinned at the faster speed. When the speed switch is turned back to delicate the basket slowed down. Any other suggestions would be appreciated. Thanks.
    It is definitely an intermittent no spin. Is there another way to test the speed dial? The high speed is working correctly. The problem would occurs after the drain cycle. Basket spins low during the drain cycle and goes to high spin. Then the basket would stop spinning. The motor and timer keeps going, and the spray cycle woul also work.
    During normal operation the basket would stop just mometarily and then it would start spinning. Eventually get to the maximum RPM. Then to the end of the cycle.
  • Ken90 Jan 25, 2008
    I definitely hear somthing, either the motor spinning or just humming with no spin.
    A load was wahsed today on heavy duty with two rinse selected. There was no spin at end of ultra clean cycle nor at end of the second rinse cycle. During both cycles, when the basket stoped after the drain cycle, I pushed the timer dial in and pull it back up and immediately the spin cycle would work fine. I hope this helps you to help me.
    Thanks
  • Ken90 Jan 28, 2008
    I took the cabinet off yesterday just to observe the motor, the cluth and the inner basket. After the drain cycle the motor continues to spin, the clutch and the inner basket do not spin. Does this help us any?
    Thanks
  • 447 Answers
You may try the speed selection switch.....Ive had problems with these.
Posted on Jan 23, 2008
  • 3 more comments
  • joey  shearer
    joey shearer Jan 24, 2008
    If you dont mind me asking if the unit sped up and slowed down than the high speed is working. Correct?
  • joey  shearer
    Ok so youre issue is an intermittent no spin complaint.
  • joey  shearer
    Does it shut down everytime when it goes to fast??
    I personally am using a Kenmore 80 series at home about 10yrs old too. Its speed selection sw failed and would intermittently energize 2 speeds and make the motor hum and click out on its overload protector. This will also smell like something electrical burning. My washer doesnt start on low and kick in to high and on the breakdown i see on the sears site its pretty much the same. If you say its always done that..than we will move on..its odd...
  • joey  shearer
    it sounds like you need amprobe to measure how much power the motor is pulling. While its in the shut down mode does it do anything if you switch the speeds around??
  • joey  shearer
    Ohh are you telling me you hear the motor still running??
Kenmore 400 series washer has an intermittent banging noise during agitation; nothing during spin cycle
might be a tranmission problem you may have to call appliance tech to fix your washer ok
Oct 21, 2017 | Kenmore Washing Machines
Tub not working in spin cycle
Replace the brake/clutch on the transmission.
You can DIY.
May 25, 2009 | Kenmore 24922 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Jan 29, 2008 | Washing Machines
Washing Machines Logo
1,242 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
