Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Blue ghost convergence shoes 2 lines and is yellow not white off to the left is 2 blue lines about 3 inches away
  • 16 more comments
  • kidrichaaaa Jan 23, 2008
    is it worth fixing is it very expensive slinteriors thank you
    is it worth fixing and is it expensive?
    can i fix it
    i do sir need istruction and what im looking for thankyou sir.
    what part to order and where i can order it
    could hooking up a new direct tv hd wires hooked wrong do this because it started when the gentlman hooked it wrong thank you
    thank you very much sir corpus christi tx. thank u
    is their a new tv u recomend that will better than a projecter tv thanks again its very helpful
  • kidrichaaaa Jan 27, 2008
    where can i order the ic and resistor thank you
    what is the differance between zenith 124-128-13 and 124-128-15 and124-143-13 which one sir
  • kidrichaaaa Jan 28, 2008
    what about resistors
    thank u 4 thelectronix its a lot cheaper in price thank u may u receive many blessings 4 your service many thanks 4 your time
  • kidrichaaaa Jan 31, 2008
    their a back order on the ic any more stores?
  • Anonymous Feb 23, 2008
    where do u desolder on back of th c board
  • kidrichaaaa Feb 24, 2008
    i replace the ic on my zenith does not turn on sounds like a electronic ignition appliance tring to turn on.
    please help
    ill check i check last night but i didnt check w a magnify glass thank u again sir.
    sir it worked i bought a magnify glasses the tv works i didnt see any resistors out both ic replace tv works tttt hhhh aaaaa nnnn kkkkk ssssssss thanks a million sir and 4 ur time.
    ur friend rich silvas
Do you desolder from the back of the board
Posted on Feb 23, 2008
  • Zenith Master
  • 8,617 Answers
Your Convergence ICs need to be replaced. If you need anything further let me know.
Posted on Jan 23, 2008
  • 10 more comments
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    Its definitely worth fixing you can get the parts for around 0 dollars, and if you can solder you can do the repairs yourself in about an hour. Let me know if you need some instructions on how to do the repair.
  • Sonny Berry
    It could have put a strain on the ICs but this is a common problem usually about every 4 to 5years you can figure on redoing the ICs. Tomorrow I will post the instructions , par numbers and where to purchase them on line.
  • Sonny Berry
    No problem. I enjoy helping people get there set back up and running. Got family in San Antonio. Denton, NC here .
  • Sonny Berry
    When you open the back panel. The board on the far left side is the convergence output board. You will notice 2 large black chips (ICs) Attached to a large Heat sink. The board location numbers are. IC2701 and IC2702 They should have the number STK392-120 stamped on them. These are the parts you will be changing.Make a diagram of which wire clips you will need to remove and mark each clip with tape and a number so you can identify where they go back when finished. When you get the board out. Locate 6 Identical resistors right next to the ICs Their number locations are R2719 throughR2722. One or two of these tend to burn out when the ICs go out.. Just de-solder the ICs.. Radio shack sells a de-soldering Iron with a rubber bulb on it. This works great to remove the old solder. You will also need a pencil type soldering Iron with a small point 30 watt to solder them back. Also they sell heat sink compound you will need a small tube of this as well. After you locate the ICs post a message and I will post a link where you can order the ICs for about 10.00 each and the resistors if they are needed. Let me know if I need to clarify anything more for you.
  • Sonny Berry
    The new Sony 46XBR4 is a great TV. LCD I have heard alot of good reviews on that model.
  • Sonny Berry
    Sonny Berry Jan 27, 2008
    Here is a link where you can order your parts.
    http://electronix.com/
  • Sonny Berry
    Zenith Model R40W46 use STK392-120 for the convergence ICs their numbers for the PC Board locatons are IC3701 andIC2702.
    Just order STK392-120 and you will have the right ICs designed for your model.
  • Sonny Berry
    Sonny Berry Jan 28, 2008
    Youre very welcome. Good luck with your repair.
  • Sonny Berry
    Sonny Berry Jan 31, 2008
    try this link, they should have the ICs.
    http://matelectronics.com/
  • Sonny Berry
    Sonny Berry Feb 24, 2008
    Check the solder connections on the pins. Are any of the pins bridged with solder? se a magnifying glass to ake sure none of the pins on the new ICs arent touching.
  • Sonny Berry
    Youre welcome let me know if you need anything further.
  • Sonny Berry
    Thats quite all right. Glad I could help and happy that your set is now working properly.
Images have some ghosting, but convergence lines seem to be OK. For example, white images have a yellow shadow to the right of image. Any suggestion?
Some easy steps to determine where and what your problem is:
1) In customer menu select convergence and then advanced (done with the Mitsubishi remote) look to see if grid of lines straight and if "yellow" is seen there.
2) Look to see if it happens when DVD etc played; If only on component from a cable or sat box but not on tuner or DVD inputs it is not the set.
3) Go to a channel that is in black and white and in customer menu turn COLOR all the way down: is problem still there or not?
If problem is not convergence and is present on all inputs it will be a problem with one of the three CRT boards; they plug onto bottom of each of the the three picture tubes this set uses; yellow suggests a problem with the blue one______loss of blue may give you a yellow smear around things/ red and green equal yellow.
You do not need to take the set apart for this.
Let me know what you find, the more you rule out the easier it is to know where the problem is.
SD TECH
Jan 10, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
A ghost blue color and it will no line up with the white cross.
The convergence circuit for the blue tube has failed. You have 2 options:
1 - you buy a repair kit and you fix it yourself - http://www.tvrepairkits.com/xcart/home.php
2 - you take the tv to a repair shop and they will replace the entire convergence board for at least $250
Dec 20, 2010 | Televison & Video
Red ghosting
You need to replace the convergence amplifiers. Mitsubishi part # 267P155010 and generic part # stk393-110. If there are 2 of them in your set, replace both.
Jun 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Cant get the Multipoint red/blue set right
Most likely your convergence circuit needs repair, there are 2 large IC chips with heat sinks (labeled STKxxx -XXX) and possibly depending on model a resistor or fuse may have went with it. 95% of the time this is all it is. It could cost $300-400 to have someone repair it.
Rustym62
http://the-tv-dude.blogspot.com
May 04, 2009 | Televison & Video
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
