Hi! I have this kind of tv and it is hooked up to a DVD player. I can get sound when I play DVD's but when I try to to listen to a tv channel- nothing. Help!
I am hooked up to Comcast and am getting the channel picture clear but no sound.I am hooked up to Comcast and am getting the channel picture clear but no sound.
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
i guess there a built in dvd player on the set and it could play most DVD format. but if you wish to use another dvd player hook up the dvd on the tv video output (DVD) to video input (TV) audio output to audio input the find the auxiliary button from either the tv or dvd
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
jtrent2- O.k you say your t.v has nothing hooked to it at all, what do normally have hooked to it. Do you normally run coax cable,or rca input. The tv is looking for your source ,hook up your regular source, and see what you get. The tv needs to see a source,of some kind. Try hooking a vcr to the cable connector on the back, play a tape and scan your channels.The tv should pick up the vcr as channel 3 or 4 and lock in. Try this and let me know,I can help you. cooltek Mar,3/08
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
You can by an AV splitter box from dick smith or even k-mart audio section that allows you to plug all your units into it, then leads go to your TV. There is a switch on the box which you flick over depending whether you want to watch a DVD or play your game unit.
The other option is to have a llok at the back of your DVD player. Some have input AV's (the red, white and yellow holes !) where you could plug your game console into. Then you just leave your dvd plugged into your tv as normal. To play your game console you turn on TV and DVD player. Have TV on "AV" channel as well as your DVD player on "AV" channel (may also be your input or component channel.
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
I don't see the new solution...
