You'll have to remove the deflection board on the left and re-solder all pins on the IFT then check the 3 brown fuses to the right of it. You should be good to go after that.
Hi
Thanks for using FixYa. This
issue is related to power supply, the processor detects a fault and the TV
shows the blinking codes. It is a fault monitoring technique developed for
TV's. You must unplug the power
cord for 4 hours, and then try again. This
will sometimes correct the problem.
Secondly, try the whack/vibration check. This
will sometimes get an errant connection or cold solder joint to reactivate. Just smack the set vigorously in various
places around the cabinet with your hand or fist in search of the magic touch!
However, if you need permanent solution then you'll need to disassemble the TV
and look for swollen capacitors; loose wire connection and bad/cold solder
joints. Also check for burnt components on the board. You will require
replacing the components and/or connectors inside the TV.
Before
replacing the power supply I will suggest you to check for swollen capacitors
and/or burnt components on the power supply board of your TV.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
