Question about Sony VAIO K45 Notebook
No power when i start vaio pcg k45
I INSTALLED A NEW HARNESS DC JACK DUE TO A BROKEN DC JACK.BATTERY WAS LOW COULDN'T CHARGE IT DUE TO BROKEN DC JACK.NOW I START IT; BUT NO POWER IT'S BEEN ABOUT10 DAYS WITH NO BATTERY CHARGE. NO LIGHTS NO SOUND NADA. ANYONE OUT THERE TO ASSIST ME WITH SOME POWERFUL INFO.....
  • brian c
    brian c May 11, 2010
    Sounds like you didn't plug something in during re-assembly.
Did you happen to clean the fan and remove that whole thing that cools the microprocessor?
Posted on Oct 22, 2008
The small flat cable from power button to board came out on mine while i was replacing the keyboard. never got around putting it right way in or something because, i have the same no power problem now.
Posted on Aug 16, 2008
Im having the same problem can't turn my computer on
Posted on Jul 03, 2008
I'm having the exact same problem. Any insight would be great!
Posted on Mar 05, 2008
    Scholar:
  • 163 Answers
Recheck the small flat cables coming from the power button panel to the systemboard.
Posted on Jan 25, 2008
The dc in will not fit the power plug anymore
I think the internal socket on the main circuit board has broken . This is common enough with old laptops.
It will have to be dismantled and the socket replaced, which is easy enough for a tech.
http://www.insidemylaptop.com/disassemble-sony-vaio-pcg-k-notebook/
Sep 13, 2012 | Sony Vaio Pcg-K45 Notebook/Laptop/Notebook...
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
Laptop won't charge
You might need a new battery....you could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing. http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-s360p-replace-broken-power-jack/
Apr 26, 2010 | Sony VAIO Notebook
Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
you can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
please take a rating let me know how much helped you thanks!
May 21, 2009 | Sony VAIO V505DC PC Notebook
Driver for radeon IGP 345M sony vaio pcg-k45
Go to the ATI web site and download the newest driver
The link is here http://www.amd.com/us-en/SupportDrivers/ProcessorSupport/0,,15218_15219,00.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 11, 2008 | Sony VAIO K45 Notebook
Vaio will not turm on
you will most likely need to replace the dc jack, which is the port where your charger plug plugs into...
To test if your dc jack is bad... Remove the Battery, Plug the Power cord into laptop then attempt to power on... If no lights turn on, no fan spins.. your DC jack is bad...
DC Jacks Cost $6 to $10 but you need to find someone experienced to replace it, or you might end up with a dead motherboard as well..
Oct 14, 2008 | Sony VAIO PCG-V505DXP Notebook
Pcg k45 sony vaio
chek the adapter and female power soket on laptop. if they are ok, clear the bios by reset bottom(there is a small hole under laptop) or removing small battery on mainboard.if the problem not solved ,have to change the mainboard.
Aug 16, 2008 | Sony VAIO K45 Notebook
PCG-K45: No Power: Internal component issue.
The Power Charging Board Is Usually Known As A PWS Board.
It should have a model Number Stamped On It. you type this into a blank webpage and do a search. this will give you the model Number i.e PWS 13 OR PWS 15 et,c.
Mike @ Compurepair.
Apr 06, 2008 | Sony VAIO K45 Notebook
Sony VAIO K45 Notebook Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
