Question about RCA HD50LPW42 50" Rear Projection HDTV
RCA hd50lpw42yx2 not working
When you turn the power on, the set clicks internally (power supply?) and the light on the power button comes on. Said light stays on for about 10 seconds, flickers once, then set clicks again and light goes out. No picture, no sound. Not sure whether the remote works or not. Thanks for your help!
  • 4 more comments
  • Anonymous Jan 29, 2008
    SAME PROBLEM - ORDERED AN NEW LAMP UNIT AND INSTALLED IT AND IT STILL DOES SAME THING. HELP.
  • Anonymous Feb 03, 2008
    same probem
  • JoeTaxpayer Dec 03, 2008
    CET - THIS WORKED!!!
    Funny, the first thing I'd have thought to do was throw away a couple hundred bucks on a bulb (as guest above did), but I followed your advice and the TV is back on. All those parts and it's these 4 caps that blow, amazing.
    Joe
  • runinguy Feb 07, 2009
    hi. anyone know exactly how to replace these capacitors? can they simple be pulled off? do you need to turn them at all?
  • hall_dean May 21, 2009
    Will NTE,CAP-1000MF 35V 105*C RAD. work to solve this problum?
  • fahqpiggy May 11, 2010
    Similar problem. So, I've opened up the back, and think I found the AC-In board (furthest to the Left, while facing the back of TV) and have found 4 1000mf caps. These are not the tallest caps and the location on the board is different from description. I just want to be sure that I'm looking at the right board. Any idea what the cap labels are?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
Posted on Feb 10, 2008
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd50lpw42yx2
Replace the color wheel.
Apr 24, 2009 | Televison & Video
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
HD50LPW42YX2 Projection
you could be looking at a problem with your power supply board not hard to replace pretty reasonably priced board definetly needs a tech to look at it
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
443 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
