Question about AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor
AOpen Monitor Botons Acting Wierd
Whenever I hit any of the bottons on top of it (poroperties,auto adjust, and volumn button a grey box appears on the botom righthand side of my screen and the bottons become unresponsive.
4 Suggested Answers
SOURCE: Colors are off after auto adjust
the same trouble with the color
Posted on Apr 16, 2008
Falcon4
  • 5 Answers
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Posted on Aug 01, 2009
cq92
  • 184 Answers
SOURCE: My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Posted on Jul 03, 2012
AUTO ADJUSTMENT LOCKED BOX FLASHES ON THE SCREEN ALL THE TIME.
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
"monitor has a green tint AOpen f2915"
moz-screenshot.png The solution: a hidden menuwithin the main menu itself. Hold the Menu button down while pressing Power topower on, and release power button only when the screen comes up, still holdingthe menu button. The menu will appear and there will now be a hidden selection,"Auto Color", printed in a red-on-black font at the bottom of themenu. Use the +/- buttons to access it, and press Menu. My green/yellow tintwent away! Now my picture works great, and the setting lasts throughAuto-Adjusts and Resets!
May 09, 2009 | AOpen F2913-8S Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Auto-adjust not correctly fixing display
was it always like this if it want go to the start botton on windows all programs accessories then system restore restore it to the date it was normal if that dosent work then re install the disk that came with the monitor if there was no disk try playing with the monitors color settings and if then still dosent work!! then right click your desktop then click properites then settings tab then there should be a little bar at the bottom you can mode ajust it to the right setting hope this helps rate!
Jan 20, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Need to Auto Adjust Envision 20" monitor every time
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Nov 09, 2008 | Proview PX-986 19" CRT Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Dec 05, 2007 | AOpen 19" LCD
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor Logo
26 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
