Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
How do I set up the picture in picture function on my tv
I have a Hitachi and I use time warner cable and I would like to know how to set up the picture in picture
    President:
  • 4,402 Answers
There should be two antennas connections in the back ant1 and ant2 connect both up to cable and click pip on the remote
Posted on Jan 23, 2008
The edges of my tv picture are left off the screen. for example the by lines on a news programe are halve missing. even when using normal aspect ratio
Which settings are you using! The ones for the cable box or the ones on your TV itself. They both have aspect features!
Dec 07, 2014 | Televison & Video
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
I just bought a 52 inch samsung my volume does not work on my cable remote.everything else works ok i have to use remote for the tv to adjust the volume. i have time warner
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
Jun 09, 2009 | LG 42LC2D 42 in. LCD HDTV
Cannot see words at the bottom of the screen.
i think you should call them first, time warner, i don't see any problem with your unit.you try evrything and only this time warner is the only problem.they are sending incompatible tv formats.
May 31, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
43FDX10B working Great until Time Warner installed cable box
try connecting the box to a different input
also try connecting another device (like a VCR) in place of the box to see if the problem exists without the cable box
Jan 13, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Digital channel set-up
Unplug the set for 12 to 24 hours. if that does not help, go into channel search but make sure the cable box is plugged in and turned on. If that does not work call out a tech to sort out your problem. Experimenting is fun at times, no insult intended, but its not the best thing to do with a TV set.
Sep 18, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
