Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Printing problem with MFC-665CW
I have a msg No paper Fed, while the paper in the try and all printing from the back side of the machine. Please help!!!
  • 3 Answers
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Posted on Jan 23, 2008
Paper tray: Feeder won't work
Do not know brand of paper, but shcek to see if feed wheels are turning when you try to feed. If wheels are turning than they are either dirty, clean with soap and water. or the whells need replacement..
Sep 30, 2013 | Brother MFC-665CW All-In-One InkJet...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
MFC-665cw unable to print 50
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment.
hen you open the printer so that you can see the print head, move the print head with your hands, pull it to the middle. The space immediately to the front of the printer is blocked by the plastic shield. you can curl your fingers down under this shield. you will feel the encoder strip, which is about 8 mm wide, and is a plastic ribbon, or strip. It runs from left side to right side across the printer, in a vertical orientation. This is the encoder strip. Past this you can feel a longer rubber belt, which is about 3 mm wide. This is not the encoder strip, it is a belt and you don't need to be concerned with this.
Place your fingers on the encoder strip on either side of the print head, and flex it, bending it up and slightly back and then release it. Try this several times. Do this with power on. Once the encoder strip is back into it's slot the printer will start a cleaning cycle and start working.
Solution found here originally.
Oct 16, 2012 | Brother MFC-665CW All-In-One InkJet...
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Will not print or shut off comes up unable to print 50
I had this same problem and it is an easy fix. It is similar on all brother printers but mine was a 5860CN.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lift the encoding strip upwards slightly and move slightly towards the back of the printer. This will locate it back into the correct position in the print head when you release. You can feel this with your fingers. Power back on and the problems will be gone!
Remember and be gentle so as not to damage the encoder strip!
Nov 27, 2010 | Brother Multi-Function Center MFC-665CW...
"No paper Fed"
Check the paper cassette and make sure the paper stop is flush up against the paper if it's not push it up against the paper and try again to print.
Aug 11, 2009 | Brother MFC-7220 All-In-One Laser Printer
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a Brother MFC-665CW printer/fax machine. It jammed with paper and once I had cleaned it up the screen now reads, Unable to print 30. I can't do anything. Does anyone know how I can fix it please?...
Normal 0 In most cases it works. Worth a try.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 15, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC-665CW
I need a manuel, I'm trying to print a 4 x 6 picture and when I take out the regular 8 x 10 copy paper and want to put in the 4 x 6 picture paper I don't know where to put it. I can print a 4 x 6 on regular copy paper but thats not what I want.
Dec 20, 2007 | Brother Multi-Function Center MFC-665CW...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
164 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
