Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Memory problems have a compaq presario sr1103wm and crucial.com claims compatible with pc2700 or pc3200 and up to 1 g per slot so i purchased pc3200 1 g sticks but when i install them it starts to boot but then quits and keeps restarting when i go to setup it shows 32 mg pc2700 whats wrong ?
  • geraldc5959 Jan 23, 2008
    when i put the pc2700 back in it will boot but not with the pc3200
  • 4,102 Answers
Hi you have to install one of each as i had this problem i brought two p100 ram sticks and installed and had same problem but when i installed 1 pc100 and 1 pc133 it worked fine but you need to make sure you put them in right slots as each slot will take different stick ok let me know if you need further assistance.
Please rate this rating as you rated the other fixya when he offered no help that was relevent to your problem
Posted on Jan 23, 2008
  • 118 Answers
Im unsure whats wrong but run the disks that came with ur pc to repair windows. that shud fix it
6ya staff
SOURCE:
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
WHAT MEMORY COMPATIBLE?
DDR PC2700 or PC 3200 RAM is compatible.
Up to 1 GB per slot.
Here is a link to Crucial for RAM that is compatible:
Computer memory upgrades for ASUS P4PE Motherboard from Crucial com
Sep 14, 2011 | ASUS P4PE-X Motherboard
I'm looking to upgrade the RAM in my father-in-law's computer (Compaq Presario SR1500NX desktop). All the "see what ram you need" searches on various websites that sell memory indicate PC2700 is...
This is the memory specs for the SR1500.
Presario SR1500NX Memory Specifications Standard Memory 256 MB (removable) Maximum Memory 2 GB Memory Expansion 2 sockets Memory Comments PC2700 DDR SDRAM DIMMs. CPU Type 2.0GHz AMD Sempron 3000+ Model Comments 333MHz FSB, VIA KM400A Chipset.
The PC2700 refers to the RAM speed, so you can use PC3200 which is faster RAM than PC2700, the PC3200 RAM should be more expensive not cheaper unless this supplier has stock he needs to unload.
You will not get any speed performance with the PC3200 RAM because the motherboard cannot make use of this faster RAM.
Dec 03, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
How much ranm can presario x1000 handle
This laptop has 2 x memory slots.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.
1GB, 200-pin SODIMM, DDR PC2700 memory module
Apr 02, 2010 | Compaq Presario X1000 Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Need to upgrade RAM
hi..ya you can upgrade the ram in your compaq
presario 5000.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Compaq Presario 5000 PC Desktop
COMPAQ LAPTOP MAMORY EXTEND
This laptop has 2 slots
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.
So maximum memory supported is 1GB.
If you install more memory there is a high probability it will not be recognised.
You can get more information and order memory from the link below:
http://www.crucial.com/store/listparts.aspx?model=Presario%20M2000%20Series
Jun 08, 2009 | Compaq Presario M2000 Notebook
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
