Question about Microwave Ovens
Microwave I blew up an egg in the microwave (Whirlpool MH1170XS) and the switch does not catch the latch. Ive got the panel off and can see the part that needs fixed, but I dont know how. Please help!
  • Microwave Ovens Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Posted on Jan 27, 2008
Ive got a d90d25eslr111-b1 micro combi,i poached an egg ani ie exploded in the micro,it blew the electic and went off,if i swith it on its ok,as soon as i shut the door it fuses the electric. why plea
see this causes and fix it. God bless you
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Sep 27, 2012 | Morphy Richards Microwave Ovens
Fuse keeps blowing
If the microwave oven is the newer type [7years or less], the problem is most likely the magnetron or the inverter board, but if model is older check for a shorted high voltage capacitor.
Aug 31, 2012 | Whirlpool MH1170XS Microwave Oven
Whirlpool microwave mh1170xs no power
Sometimes you get lucky with just changing the fuse, the most cost effective way to fix a microwave oven.
Jul 01, 2012 | Whirlpool MH1170XS Microwave Oven
Does model MH7110XB have a fuse? We have no power and have tried checking the circuit but no luck.
Yes it has a fuse. Take the cover off and the fuse is on the right hand side, behind the control panel
Feb 28, 2011 | Whirlpool MH1170XS Microwave Oven
Where is the fuse located on the MH1170XS and how do you get to it?
Fuse is usually located behind the control panel. Most likely 20 amp. If your m/w has a top grille it will have to be removed. Look for a screw in the top of the control panel. Panel has tabs to hold it to body, lift up to release panel. A word of warning... m/w ovens have potentially lethal high voltage present even when the unit is unplugged. If you are not familiar with high voltage circuits, then this is not a job for a DIYer.
Dec 28, 2010 | Whirlpool MH1170XS Microwave Oven
My whirlpool microwave MH1170xST-0 works except it does not heat the food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 06, 2010 | Whirlpool MH1170XS Microwave Oven
Microwave not warming
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
But If the microwave doesn't work at all , then It could be a problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
CAUTION: A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH1170XS Microwave Oven
Brand new.......clicking noise, will only run 2 seconds
Since it's new, I would let Whirlpool cover the repairs.
You can contact their customer service at
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Whirlpool MH1170XS Microwave Oven
Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Jul 08, 2007 | Sharp R-408J Microwave Oven
Microwave Ovens Logo
199 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
