The upper thread (one coming down from spool and through needle) is getting caught around the shuttle. This is causing the thread to bunch up underneath the fabric. As a result the fabric jams and when pulled from the machine there is a ton of thread stuck in the shuttle area. I tried re threading and cleaning the shuttle area. HELP!!! Trying to finish Christmas quilt :(
won pickup the bobbin thread Google SearchOne Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
- Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
Remove any loose threads or lint in the shuttle race.One Point Advice Installing a bobbin into a bobbin case
- You could be holding the needle thread too tight.
Hold the thread lightly to keep the end from going down into the shuttle.- The needle could be thread incorrectly.
Thread the needle eye from the front to the back.- The needle could be bent or improperly inserted.
Install a new needle with the flat side of the needle facing the back.- if this does not help you go to this link.
The bobbin thread tension
has already been adjusted at the factory for general use. For most
applications, no adjustment is needed.
When sewing with then
thread on thin fabrics, the thread tension may not be adjusted adequately with
the upper tension control dial. Therefore, the thread tension must be
adjusted according to the procedure described below.
If bobbin tension is too
loose and locks appear on the surface of the fabric, decrease the thread tension
by turning the dial to a lower number.
If the result is still
not satisfactory, then adjust the bobbin thread tension.
Increase the tension in the bobbin by turning the screw with a small screwdriver in a clockwise direction. However, do not turn the screw more than one full turn.
