Question about GE WBSE2090A Top Load Washer
Drain problem in GE WBSE2090A washer
Water is not fully drained from the washer after spin, and I think it causes bad smell inside the washer. I do not see water within washering basket. But I can definitely say there is quite amount of water under the basket after the cycle, which I can't see but I can hear when I shake the machine around. What should I do?
    Problem Solver:
  • 6 Answers
Hello, if you washer is not or isn't fully draining that sounds like something might be in the pump.Icheck for any hose blockage as well.If there is a bad smell that might be dirt or a peice of clothing or anything. so my suggestion is to check your drainage hose, the pump or maybe try even to syphan out the pump which means put the drainage hose in a bucket lower than the washer or your drainage is higher than the washer. good luck...
Posted on Feb 11, 2008
I have an older Whirlpool duet that reads sue code.It has water that has not drained fully with a odd sound towards the rear of machine possibly a short in board?
Is it SUE or SUD code?
Sud SUDS LOCK (Overdose of detergent detected during the wash cycle) The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Dec 06, 2013 | GE WBSE2090A Top Load Washer
What dose oe mean on the display and it makes a grinding noise when it drains the water i think
Drain error: Not fully drained in 10 minutes. Causes: Drain hose too high. objects in pump, drain hose kinked, drain hose air locked, bad control.
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washer still has lots of water in it at the end of the spin cycle. Also, we notice bad oder each time the washer is used. Are these related? How do I fix this problem?
The most common problem is the water pump is malfunctioning and not allowing the water to drain all the way out, if the machine sits over a week the water turns sour and smells bad. so check that the pump is not plugged up and check that the pipe from the pump is not plugged up. if hose is not plugged up and the belt on the pump is tightened up it could still be a bad water pump so I suggest you replace it. Also with a water hose push water threw the drain pipe in the wall to see if the pipe is plugged, it should take full water hose pressure without a problem, if it backs up then you have a plugged drain pipe. remove the drain pipe form the hole in the wall and push hose onto the water hose put washer on spin and have other end off the hose bib, watch the water flow as it pumps water out of the spin cycle if the water does not come out fast than you have a bad pump or a bad water pump belt. since it won't drain all the way this will cause the water to smell sour.
Dec 13, 2009 | GE Washing Machines
Wont spin
motor coupling is the problem. You have two one for the motor and one for the transmission one of these are broke.It does agitate doesn't it?
Sep 03, 2009 | GE WBSE2090A Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
I have a washing machine that won't drain or spin
Take the hoses off the back of the machine and clean out the screen inside where the hoses where attached. Also check both ends of the hoses to make sure there are no screened hose washers there which need to be cleaned or replaced. If all clear, a new water inlet valve may be needed, but most likely it is just the screens in the inlet valve.
Dec 01, 2008 | GE WBSE2090A Top Load Washer
It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
GE Washer overfilled, now won't spin
Could possibly be that the water level switch in the console has gone bad.  Sometimes the small hose that connects the basket and the switch can come off, causing the overfill.  Sounds like maybe the water switch has gone bad though if I were to guess at it.  If it goes bad, it will send the timer a signal that its full, when its not.  Could also be a bad timer, but that only happens on rare occasions, but it does happen.  Let me know how it goes or if you need break down instructions, etc.  Jim
Oct 16, 2007 | GE WJSR4160D Top Load Washer
GE WBSE2090A Top Load Washer Logo
114 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
