Question about Toshiba 32A33 32" TV
Buttons don't work
I have a Toshiba 32A33 32", and it seems like it's taking its own decisions. The buttons on the front panel don't work and I stopped using it 'cause sometimes sound goes louder and louder, and it changes the channel by itself... until I unplug it. Is there anything I could replace? My brother is a technician and I could tell him to replace or fix any part for me.
  • jesnang Jul 04, 2008
    Have a similar problem, our tv has a mind of its own. The volume will go all the way up and we can not control it. Can't turn the power off with the controll or pushing the on/off button so we have to unplug it. Then there are times that the volume will go all the way down and same thing we can't turn the volume up. None of the buttons will operate on the TV during these moments. What can we do??
Cardpsycho is right.  We had the same problem, among many others (unresponsive remote, none of the buttons on the set working at all).  I taped a penny very firmly over the tv/video button on the set to keep it depressed at all times.  This fixed everything!!!
Posted on Oct 04, 2008
  • Anonymous Oct 06, 2008
    Hi folks,
    Just to update, the penny method hasn't work very long, but I still couldn't find a piece of plastic to wedge, so now I've tried the corner of a wooden shim.  I wedged it in until the button was depressed, then snapped it off and taped it down firmly.  So far, so good...  Back to the Red Sox for now...
  • 3 Answers
Just a quick fix that might work wedge something between the video button on your tv to where it is pushed in all the way then your tv shouldnt have a mind of its own anymore and the romote will work again . Just saying this cause had the same problem and thats what I did and my tv work fine again
Posted on Oct 03, 2008
You have to change some of the switches,or maybe all of them.You can use a multimeter to test it one by one.
Posted on Jan 23, 2008
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Toshiba tv keeps on changing inputs at irreguar times on its own and the every button on the remote changes the input. have tried removing batteries from remote but problem continues
There is a known problem with Toshiba Tvs that options change with out any input of buttons or remote. the tv switch panel needs replacement. This is situated behind where the buttons are on your tv usually bottom right. there is a work round if you dont want the expense of part replacement. you can disconnect these buttons and only use the remote. This requires taking off the back (ensure tv is disconnected from power as there is high voltage in the tv) once the back is removed and tv is laying on its front you will see bottom left where the buttons now are, a couple of cables one will have seveal wires and one will only have a couple of wires take the smaller one off this will disconnect the buttons and stop the problem. once this is done you can only use the remote control to control the tv settings but the power on off button still works.
I hope this was useful.
Apr 05, 2011 | Toshiba REGZA 32AV615 32 in. LCD TV
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
Dec 13, 2009 | Toshiba 36A43 36" TV
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
Canon ir 400s
Try cleaning the control panel and all the buttons/keys. If problem persists, try banging the keys individually. The control panel will not respond if any of the keys are stuck down.
Sep 15, 2007 | Toshiba e-Studio 205 Copier
DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
Jul 23, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Toshiba 32A33 32" TV Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
