Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Cant remove water filter
Feels like a "vapor lock". Feels like it is about to come loose but no amount of force will remove it. ANy suggestions appreciated.
  • jgray11111 Feb 13, 2008
    Tried everything short of breaking plastic. Drilled the hole and it came off. Thanks and my wife says double that.
My puriclean 2 filter would not come out.
finally the only thing that worked for me was to
turn the filter back and forth as fast as i could while
steadily pulling on the filter with my other hand.
dont gorilla pull or you will tear the dispenser out!
Posted on Feb 21, 2008
    Scholar:
  • 42 Answers
Jgray11111,
I am guessing you know to turn the filter fully counterclockwise, to remove it.
My first suggestion would be to turn the filter fully counterclockwise until the dead stop, then while holding the filter with one hand you would push and release quickly the water dispenser lever. The pressure should pop the filter out of its socket.
My second suggestion is turn filter counterclockwise to dead stop, then take a very hot towel (protect your hands and to not touch towel to any glass shelves) and wrap it around the filter. This method will hopefully warm the water in the filter causing the water to expand and help push the filter out of its socket.
My third suggestion would be more extreme. Turn the water supply off. Turn filter counterclockwise to dead stop, then drill a hole in the side of the filter to allow air into the filter to release any vacuum in the filter allowing you to pull it out of the socket.
If none of these work then the filter socket probably will have to be disconnected so you can get it out of the compartment and get a better grip on all.
I have never had to go that far myself.
I hope I have helped you and please don't forget to rate me.
supertechks
Posted on Jan 26, 2008
  • Keith Smith Feb 13, 2008
    You have no idea how happy it makes me to hear from people I try to help. That is why I do this. I am glad that tricks I have learned can be passed on to others. Your description was very helpful and the vapor lock comparison was brilliant. I have run across this only a few times in my job. I am happy to have been of help.
    God Bless, supertechks
Having trouble with vapor locking
Vapor lock can be caused by many different things, all coming down to the same root cause: too much heat in the fuel feed lines.
Low fuel pressure can cause the amount of heat needed to vapor lock to be lower than normal, so checking fuel pressure is important. Fuel pump going out feels a lot like vapor lock.
Engine overheat can also cause vapor lock. Clogged fuel filter can cause vapor lock. The fuel line should be routed away from the exhaust system.
Feb 29, 2016 | Cars & Trucks
Why does it miss between 50-60mph
Gas would do it all the time.Fuel filter may be stopping the flow of gas causing a misfire. It sounds water in gas but just at High RPMs like it is vapor locking (not getting the right amount of fuel). would change the Gas filter, Air filter, (gas Treatment to remove any water like Sta-Bil ).If it goes away your lucky. But it looks like a fuel pump is getting weak.
Jun 25, 2014 | 1998 Dodge Dakota
Starts but wont run and shuts down in seconds
Read entire posting before doing anything else first.
I discovered what the problem was, after changing spark plugs, fuel filter and air filter (At this point the mower would not start at all):
1. Checking for spark. I got spark out of both plug wires. The modules were OK.
2. Checking for fuel flow. Only small amount of fuel coming out of fuel pump. I changed the fuel pump. (I bought a Briggs and Stratton for $22.50 instead of a Kohler for $60.00. Same fuel filter!)
It ran fine for 10 min. then quit again!
I loosened the gas cap and it has ran fine since then, by keeping the gas cap loose. I will replace the gas cap.
Note: It was difficult to find the problem, since I replaced the filter and removed the vapor lock, so it ran for awhile. I then checked the fuel pump and removed the vapor lock, so it ran for awhile. I would suggest that people with similar problems, loosen the gas cap to see if that works first!
Sep 05, 2013 | Craftsman Garden
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Looses prime.
Those of you having a pumping problem with the Keurigs with side maounted tanks. It seem that the screen in the base when you liftout the tank you can see it, has a tendency to vapor lock due to the small mesh and pump height. I corrected this by putting 4 larger holes in the screen which is plastic with a pointed object just be careful not to go to far down or you will puncture the hose for the pump. After doing so I have not had a problem with my pump supplying water for the last 2 weeks to the heat tank, if your pump is not humming or working this will not work. This is a fix for those that remove the tank and set it back and the pump works when this is done you are forcing water through the screen breaking the vapor lock so try it, if it works fine
Feb 09, 2011 | Keurig Platinum B70 Coffee Maker
I need to replace my fuel filter. need to know where it is and what i need to do to access it.
Regarding Fuel Filter - Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line.
A device located in the fuel line to remove impurities from the fuel before it enters the carburetor or injector system.
INSPECTION
Fuel filters can be located in a fuel line, in the tank, in a carburetor, or in any combination of these. A carburetor often has a filter behind the fitting at its fuel inlet.
A carburetor inlet filter. Courtesy of General Motors Corporation, Service Technology Group. Fuel filters that are installed on the outlet side of a fuel pump are called outlet filters.
An external fule filter. Courtesy of General Motors Corporation, Service Technology Group. Engine heat causes fuel to vaporize, which can result in vapor lock in the filter. Some fuel filters have vapor return lines to allow for expanding vapors and fuel to return to the tank.
A fuel filter with a vapor return outlet. Courtesy of AlliedSignal Automotive Aftermarket. Fuel injection systems require larger, heavier duty filters than carburetors. They filter out smaller particles of dirt while still allowing the pump to supply a substantial amount of fuel.
REPLACE
Fuel filters and elements are serviced by replacement only. Some vehicle manufacturers recommend fuel filter replacement at 30,000 miles (48,000 km). Always replace the fuel filter at the vehicle manufacturer's recommended mileage.
The fuel filter replacement procedure varies depending on the make and year of the vehicle and the type of fuel system. Always follow the filter replacement procedure in the appropriate service manual. The photo sequence below shows a typical procedure for relieving fuel pressure and removing a fuel filter.
Removing a Fuel Filter on an EFI Vehicle
Disconnect the negative cable at the battery.
Loosen the fuel tank filler cap to relieve any fuel tank vapor pressbae0f2b.jpga678067.jpg
Connect the fuel pressure gauge to the Schrader valve.
Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
Oct 08, 2009 | 1997 Chevrolet Malibu
2005 Polaris 700 sportsman 4x4 gets warm, looses power?
My 2005 700 efi is doing the same thing. So far I have found that the engine and exhaust get so hot that the fuel starts to boil and causes the fuel pump to vapor lock. I taped up the tank with some reflective tape/insulator stuff and now I'm trying to figure out why its running so hot.(The exhaust manifold glows red hot) I've cleaned the radiator and flushed the system. I just need to check the water pump and thermostat. Any other suggestions?
Mar 07, 2009 | Polaris ATV
Runs, but nothing comes out
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Aug 30, 2008 | Bemis 526 300 Humidifier
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
182 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
