Question about NexxTech 4-Port Ethernet Broadband Router (N4PROUTER)
My N4 Router Isnt Working!!!
My router used to work, but not anymore for some reason. When i connect it to my xbox and my computer, the xbox works but the internet wont work on the computer. It says there is little or no connectivity. Please help me fix this problem i have no idea how. Thx
Open Control Panel, Go to network settings, right click Lan connection, click properties, disable firewall
Posted on Jul 16, 2009
Netgear RP114 Stopped connection with Xbox Live.
You say "it does connect to other computers on my network (Media Streaming) through the router" but it's not connecting to "Xbox Live"? If so, it sounds like a problem with your Xbox Live subscription.
Jun 08, 2017 | NetGear RP114 (RP114CN) Router
My belkin N600 router will not connect to my internet
Router should be connected via RJ11 cable to the phone socket to get internet service. Check the RJ11 cable at the back of the router. You can try to use a different RJ 11 cable for isolation or try to use the cable that you are using at the back of your phone. You can also check if you are getting a dial tone on the phone as well.
thanks and kindly rate this post
Jan 03, 2012 | Belkin Play N600 Wireless Dual Band Router...
My XBox live connection keeps dropping out in the middle of a game. It can be working fine for a couple of hours and then it drops out for no apparent reason...have to reset the router and modem and...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 14, 2011 | Belkin N1 Vision Router
Xbox router isnt working
connection problem insert a pen drive an connect please vote.
Nov 09, 2009 | Microsoft Xbox 360 Console
D-link connection to xbox live . works fine on computers
We had a problem with our Xbox doing this, take a cable from one of the comptuers and then try to hook it up. If that don't work, look at the MTC or the username and password information for the router which you might need on the router. Do you need a username and pass for the router? If not then you can connect directly without putting the pass into xbox. This may help, but that was what the problem was on ours and Idk if it will work for yours.
Apr 09, 2009 | Computers & Internet
Connect xbox360 and linksys wrt54g
There are several possible reasons why XBOX doesn't connec to the Internet through the router:
  • Check physical connections between XBOX and router.
  • Try different Ethernet ports on the router and use known working Ethernet cable.
  • You may also connect your XBOX directly to your modem and check if it will connect to the Internet.
  • Check the IP address that your XBOX is getting when connected to the router.
  • Take note of the error message you get from XBOX for us to know the real problem.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Internet connection to two devices
julianlee
can you tell me what type of router you are working with.
most routers have about 4 cat five cable slots where you can plug them into other computers. If you have a wireless router and you have a wireless adapter for the xbox that will work also.
another question are you working with the xbox360 and if so do you have an xbox live account?
another thing you might have to go into the setting of the router usally on the main computer to do this you will have to bring up the command prompt where it can be found at for windows 98/2000/xp/vista <start >all progams >accesses command prompt > type in ipconfig it will pop up with a default gateway and your ip you take the default gateway open your brosswer type it in. If you have not set up a password most routers have it as admin. from there i would need to know what kind of router you have ! hope that helps a little
let me know
djkb
Jun 21, 2008 | Computers & Internet
My N4PROUTER isnt working :(
isolate your problem. maybe it has something to do with your computer. try connection your pc directly to your modem. if it gets online there. the problem is with your router. try unplugging and replugging your router then restart your pc.
Jan 24, 2008 | NexxTech 4-Port Ethernet Broadband Router...
Xbox360 connection problems
It appears we need to buy a different router. There is no way to change the MTU on the Blitzz BWA711
Nov 01, 2007 | Blitzz Technology BWA711 (B3WL000900)...
NexxTech 4-Port Ethernet Broadband Router (N4PROUTER) Logo
151 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
