Question about Vivitar ViviCam 8025 Digital Camera
Why after 8hrs charge am I only getting blue screen/w MSDC
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The blue MSDC screen simply tells you that the camera is connected to the computer. To use the camera, disconnect it from the computer.
Posted on Feb 24, 2012
5 Suggested Answers
SOURCE:
skyhoneybear
  • 17 Answers
SOURCE: Blue Screen MSDC
You should only get that screen when it's charging on the wall charger or when it is hooked up to your computer via the USB cord.
Posted on Aug 15, 2009
SOURCE: i can't get my brand new vivitar vivicam 8025 to
My roommate had the same problem, pretty easy to fix. Make sure your memory card and battery are all the way in and they should lock. If you lost the booklet, the positive/geative signs should be on the bottom right when sliding it in.
Posted on Jan 05, 2010
  • 11967 Answers
SOURCE: et blue screen and message msdc on screen.
msdc stands for mass storage device. Try removing the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: is my camera charging when plugged in with usb
The charge light on the back of the camera will light red while charging and go out when fully charged. Your camera should have also come with a separate battery charger if the above method doesn't work.
Posted on Jan 09, 2010
Why does MSDC , WITH BLUE SCREEN, appear WHILE CHARGING BATTERY?
You're charging by connecting to a computer's USB port? The MSDC simply indicates that the camera recognizes the connection to the computer. It should go away when you disconnect the camera from the computer.
Aug 26, 2014 | Vivitar ViviCam X029 Digital Camera
Msdc blue screen on my camcorder
Try to go thru menu and do a factory reset?
Mar 10, 2014 | Vivitar ViviCam 8025 Digital Camera
Vivicam 8025 what does the MSDC screen mean while charging
The MSDC indicates that the camera has recognized it's connected to a computer.
The red light indicates that the camera's battery is charging.
Aug 03, 2012 | Vivitar ViviCam 8025 Digital Camera
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
I just bought the camera and am trying to charge it. I am not getting an LED light but instead a blue screen that says "MSDC" in white letters. I have checked the battery and storage disk...
Are you charging it by plugging it into a computer? The "MSDC" you see usually means "Mass Storage Device Class", which basically means the computer is using the storage on the camera as a removable drive. This would usually happen when plugging a camera into the computer via USB. There is usually an AC adapter that comes with a camera, or a separate charger for just the battery. If there was no charger that came with it, the camera is probably still charging. If the camera is on, try turning it off and plugging it in. Remember, even if it shows "MSDC", it is probably still charging. Hope this helps!
May 19, 2011 | Vivitar ViviCam X029 Digital Camera
My vivitar vivicam 8025 has been charging for a while and it wont turn on with out the charger . when connected to the charger and turned on it says MSDC on a blue screen.
Make sure the battery is in the camara correctly. I had the problem with the blue screen and MSDC showing and it would not hold a charge. the battery has to be in correctly. It will go in wrong and look right so match up the silver three marks on the battery to the three marks inside the camara where the battery goes. It worked after i did that. Hope this helps!!!
Oct 28, 2010 | Vivitar ViviCam 8025 Digital Camera
Et blue screen and message msdc on screen. cant get anything else. Will not turn on and screen goes off if unpluged. Have charged for 3 days. Vivitar Thanks
Dec 28, 2009 | Vivitar ViviCam 5385 Digital Camera
My vivitar will not come on a blue msdc screen and blinking red light
I just called the help desk. MSDC and a blinking red light means that it is charging. It takes 6 hours to charge and you are not to take disconnect it from the USB until it is fully charged. Once it is charged the blinking light will turn green.... not sure whether it will still be blinking or not. This is what the lady on the phone told me so I haven't been able to try it out yet, but I will update if I call again.
Dec 26, 2009 | Vivitar ViviCam 6300 Digital Camera
Msdc screen
i keep geting msdc on blue screen on my viviar 8025 vivicam can you help thanks mal
Sep 11, 2009 | Vivitar ViviCam 8025 Digital Camera
Blue Screen MSDC
Aug 04, 2009 | Vivitar ViviCam 8025 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
614 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
Jeff
Jeff
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
