Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
WD62725 Lamp I replaced the lamp in my wd62725 tv only to have it not work. I left the door off of the lamp compartment and closed the interlock switch to see if the lamp was coming on. It was coming on ,but only for about 10 seconds. Then I would get a 34 code. Could anyone help with this problem? Thanks John
    Sergeant:
  • 395 Answers
Code 34 is lamp abnormlality which what you are discribing is most likly the balast, since the lamp comes on for a brief second then shuts down. the part # 939P978010
Posted on Jan 23, 2008
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Tip
DLP TV won't run after replacing lamp.
When the lamp on your DLP blows out or the "replace lamp" light says it's time to replace the lamp, you do, then the unit will not power on you may not have inserted the lamp fully, correctly or the interlock switch may not be closing completely on the lamp door.
For safety purposes DLP TV's have an electrical interlock where the lamp door closes. The set cannot be energized with the lamp door off or open. If you remove the lamp door you should see an arm on the door and a slot in the frame with the contact for the switch visible through it. Make sure that the arm is not broken off or damaged in any way.
With the door removed, remove the lamp assembly being careful not to touch any of the glass. If you still have the replacement instructions reread them and follow the reassembly instructions carefully.
Be certain that the lamp assembly is installed properly and seated completely on the power plug. When you are absolutely sure that it is mounted correctly, attach the lamp door making certain that the interlock is being depressed by the arm on the door.
If the unit still does not power on remove the back from the set. This generally involves removing many screws around the perimeter and should be obvious if studied for any length of time. Once the back is removed look at the interlock switch and make sure it is mounted correctly. Many times removing and reinstalling the lamp door will move the switch (if it is loose) causing the switch to not perform it's task and clear the fault for the lamp door.
If the unit appears to be mounted correctly use a DMM to check the continuity of the switch both open and closed. If the switch shows continuity when depressed it is good. Reassemble the unit and try it. If the lamp door switch was the problem you unit should now work.
If your unit still will not work I have a tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv which may be helpful for more advanced troubleshooting.
Thanks for using FixYa.
hardrocko
on Jul 01, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Replaced the lamp in a wd62725. Green lights blinks fast but never cuts off.
need to have chassis completely rebuilt, specially p/s and fmt board. expect to pay around $500
Dec 10, 2009 | Televison & Video
How can i remove a screw with an interlock???? I need to replace the lamp in my hitachi rear projector t.v.
unplug the tv .then remove screw-> lamp door -> lamp..Interlock is going to be a swicth engaged by the lamp door that is supose to disable the parts that might give you owies when replacing the lamp. (incase you don't uplugg the tv first). ALSO you must to put the lamp door back on after replacing the lamp.(or else Mr. interlock switch won't let the tv turn on )
Oct 03, 2009 | Televison & Video
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv problem mitsubishi wd62725 ir location
This remote device works on pulsed IR beams to work, and the fact that the screen refreshes very close to the speed of the controller could be causing the reliability problem..Sorry I don't have a better solution for you....accordianman
Nov 11, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
249 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
