Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Tv tunner reception
Hello i have some problem with my tv card reception, i hook it up on our cable but there is some interference like a horizontal line accross the display, is there anything u can suggest to fix the problem..
tnx..
    Genius:
  • 1,067 Answers
Try to update all latest drivers for it software 1st ok and dl latest drivers for your video card ok
Posted on Jan 23, 2008
Tv-tunner cannot render audio capture stream
What cable connections are you using? HDMI has to be enabled on you motherboard (high def. audio), if its S-Vidio you must run a seperate and dedicated audio cable from headphone jack to TV.
My first gues would be to right click your audio icon on your desktop toolbar and check your playback and recording settings, make sure the tuner card is the source, hope this helps!
Apr 03, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
The TV pictures is on and off all the time. Help.
You need to give more information about you set-up. What type of components are you using with the television. What type of signal source are you using for reception. Cable box, or satellite box. Do you have any other electronics around the television that may interfere with the televisions signal reception. This problem could be a bad cable connection or antenna connection. Try checking the connections. Replace the cables if they look old and dirty.Try moving the cables around as you look at the picture to if the reception gets better. If it does then you are getting interference from the interaction of the magnetic fields around the cables. You need to isolate them and see if you can find the cable that is causing the interference. Check all the ground connections of the cables to make sure that they are clean and making good contact. If these suggestions do not resolve your problem. Use this web address to go to the PROSCAN website for customer support help. www.oncorpus.com. The customer service number is 1-888-977-6722. I hope this Information has been helpful to you, with your problem.
Apr 12, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Just the one TV freezes
hello, it possible if your sharing the signal to sometimes loose reception you should have a dedicated hdtv antena or hdtv cable service for your main tv.
you can check by removing all the other sets and see,
if it happens again then you need a dedicated hd antenna or signal. this should be better for you and your hdtv reception.
Dec 17, 2008 | Vizio VU37L 37 in. LCD TV
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Capture video from composite input
you should make sure everything that may cause interference is away from any of those cables, such as cable/dsl modem, wifi router..etc because they cause a large amount of electromagnetic interference
Nov 02, 2008 | Pinnacle DV500 DVD Video Capture Graphic...
Aver media tv tuner card....helpppppp
First things First:
1) what is the real problemyou have?
2) if is a TV tunner, verify the brand, and look for software or generic software for TV TUNNERS. then install and run again. it is suppose to have a support page for any problem.
look.:
http://www.aver.com/mpd/support/download/download.html
Mar 21, 2008 | Computers & Internet
Toshiba 37 inch TV
do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Dec 10, 2007 | Toshiba 37HL67 37 in. LCD HDTV
About tv tunner card
Do a google search for a tuner in your area. Should give you a price.
Sep 13, 2007 | Compaq Armada 7400 Notebook
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
