Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
PROBLEM USING SCANNER
I am using a MFC-240C printer. i am able to print and copy. when in the scan mode however, the lcd just says'connected to pc' and nothing else happens. The computer keeps saying it does not recognise the scanner. What can i do?
  • 2 more comments
  • Anonymous Jun 12, 2008
  • dawn macijeski Jun 12, 2008
  • amat08 Jun 21, 2008
    I am using MFC-240C, the installation CD on Win XP cannot work on my PC, so i downloaded from this site, but when i finished install, the installation diagnostics said my scanner fail, but my printer and fax is ok. So how can i get help? - from amat
  • tez-ball Sep 18, 2008
    hi i have he same problem but it is with the HP Photosmart C4200 series can u help me please
Try to disable the Windows Firewall and see if it works.
Posted on Feb 08, 2008
How can i scan
Posted on Jan 29, 2008
  • 3 Answers
Hi NattyNatty,
The issue seems belong to software. You can remove or repair MFL-Pro software (including in CD-ROM).
Posted on Jan 23, 2008
How to use scanner mfc240
Welcome to Fixya.
Click on the link below to take you to Brother's support page where the user's guide can be viewed and downloaded. It also features a detailed instruction on how to use the scanner function :
Brother mfc240 Manual
Thanks for using Fixya.
May 14, 2011 | Brother Multi-Function Center MFC-240C...
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black line down page when in COPY mode on MFC-240C
You need to poiwer cycle after cleaning as the scanner only calibrates during power up. If all is clean, even the white bar over the small glass assembly, and you power cycle the machine and it's still there, you will need a new scan assembly.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Incomplete scanning and copying
is your scanner glass clean?
if not, clean it tells u hell in the user guide
Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Won't scan
I would uninstall the dodgy mydvd program, and use Spybot to clean up the malware it has spread on your system.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Brother MFC240c) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Scanner
Can you copy?
If yes, what windows system do you run and did you install the complete mfl-pro suite?
How do you connect the machine to the pc? Do you use a hub or did you connect it directly to the pc usb? The latter one is the right one for scanning.
Nov 19, 2007 | Brother Multi-Function Center MFC-240C...
MFC-240c
Remove all the software. Run the worm cleaner software again Restart the computer Ensure you are off line and the Anitvirus program is disabled. Reinstall the software and follow the instruction exactly. Worms don't eat printers
Sep 03, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
