I have the exact same problem. Will fill, motor will run but no agitating. Water will drain, but no spinning, motor just continues to run.
Has anyone got the repari done? What was the problem?
I bought the unit at a refurbished/dent warehouse this time in 2006. I replaced the pump last year & now this. A $300 washer is now costing me $500 if i call the repair man back out--should have just bought a brand new one with a warranty. I have the exact same problem. Will fill, motor will run but no agitating. Water will drain, but no spinning, motor just continues to run.
You can't post conmments that contain an email address.
Hello Friend, The problem is the motor coupler has broke. Replacement is easy, it's installed between the motor and transmission. Almost anyone could replace that part themselves.
Tim, at: JustGetitFixed
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
did you try checking your belt to see if its real lose?That might be it!.I have a question for you about this washer,do you know where the lint catcher is?.
i have same problem.
dt
