Question about Pioneer DEH-P7700MP CD Player
Pioneer cd player deh7500mp
I want to install this cd player into my 1998 mecury mountineer but i need help
3 Suggested Answers
  • 624 Answers
SOURCE: Need a manual for a pioneer premier car stereo
Try this link, it is Pioneers website and you can get the owners manual for your unit if they have it. You did not list your model number, so i could not verify if they have it.
Posted on Nov 21, 2008
  • 41 Answers
SOURCE: trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Posted on Feb 22, 2009
  • 1114 Answers
SOURCE: Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
Posted on Aug 17, 2009
0 characters
1 Points
I need the wiring diagram for the stereo of a 1998 mercedes 320 ml
Here's a link that may be of some help. Scroll down page a bit, and they are listed.
Jan 31, 2010 | Pioneer DEH-P6800MP CD Player
Wiring diagram color codes for pioneer 6800mp cd player
what car is going into and in what country was the pioneer bought
May 15, 2009 | Pioneer DEH-P6800MP CD Player
Check this site out..It help me when doing mine and all info is free..
Apr 19, 2009 | Pioneer DEH-2100 CD Player
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
Wiring problem
Here is the support page for the manula and the installation instructions. Solved?
Dec 30, 2008 | Pioneer DEH-P3500 CD Player
give me your email and ill send you the wire diag
Nov 12, 2008 | Pioneer DEH-P2900MP CD Receiver...
Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Jul 06, 2008 | Car Audio Receivers
Pioneer deh 2300
buy a build ur own connectr at radio shack use all the pins then just figure out what wire goes to what
Mar 29, 2008 | Pioneer DEH-2300 CD Player
Pioneer deh-p2000 cd player
I checked the Pioneer Database and your device is no longer supported.
But I have installed several Pioneer products over the years and they a re pretty consistent in their wiring patterns.
There is a Yellow wire on the harness that is much larger diameter than the rest. This is the one that needs to be connected to a constant +12 volt source to alleviate your problems.
Best of Luck.
Oct 30, 2007 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P7700MP CD Player Logo
221 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
