Question about Hitachi 50UX57B 50" Rear Projection Television
Blurry picture images shadowed
My picture today started to have a shadow effect in different colors. Green, pink, etc.. The picture is blurry and letters seem to be shadowed in different colors.
    Sergeant:
  • 395 Answers
Your convergance amplifiers have gone bad they are stk392-110 but you can replace them with stk392-120 there are two of them in the circuit. there may be some support resistors that have gone bad I'm including a link to a service manual. if you don't have the ablity to do this repair leave it to tthe pros.
https://www.vancebaldwin.com/shop/research_new/HIT/50UX57B.pdf
Posted on Jan 23, 2008
  • 86 Answers
Your convergence is off. You may be able to fix it by pushing the "Magic Focus" button on the front panel of your TV. If this doesn't fix it, it may need to be professionally aligned or some IC chips replaced.
  • 2,427 Answers
Your filter capicators are proberally damaged, get a technician to have a look ate them, alsoe you might want to try your image adjustment.
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Picture is blurry and i see green and pink shadows
you need a light engine. please contact Sony and see if your still under the recall for that model.
Jul 02, 2010 | Sony KP-43T90 43" Rear Projection...
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bad convergance, blurry
you are having a convergence fail. would need to replace the STK convergence ICs. they are probably going to be STK392-040 and there are 2 of them. you would also need to check all the pico fuses around the area.
Feb 20, 2008 | Samsung PCL5415RB 54" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 50UX57B 50" Rear Projection Television Logo
198 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
