Question about ECS 945GZT-M (V1.0) Motherboard
Powering up, but no video display
I've recently purchased this mother board and a brand new video card. Problem is, even when connecting to the video card, nothing shows up on my screen. I'm almost sure it has something to do with me pulling out the Cmos pin on accident. Any suggestions?
  • 1 more comment
  • jethro429 Feb 12, 2008
    I can't get the system to boot, no vga out, no keyboard, nothing. Any help?
  • jjes Mar 31, 2008
    I have the same problem with this motherboard. Any solutions that worked? I read somewhere that clearing the cmos should fix the problem.
  • waltercross Sep 27, 2008
    I Have same issue, no display, no Keyboard(though the Keyboard Jack works), I Resetted Bios, took out batter etc, nothing fixes it, but Fans, Lights, all work, DVD Drive loads up(It's lights indicate this), Hard drive spins, not sure whats going on.
    Genius:
  • 1,067 Answers
U back cmo pin on 1 2 only 23 resets it wont boot do u have onbord video out port use thatto see in bios then change it to pci express or agp whetevr uuse to boot off 1st in inet disply ok
Posted on Jan 23, 2008
Screen dark on monitor
1. you possibly have a malfunction inverter board which is internal to the PC.
2. this will require a qualified tech to dismantle the pc and replace the component board that connects to the video card that is integrated to the mother board.
2. if the video card is not working this will require a new mother board to be installed.
3. there is a cable also in some models that connect the video display to the mother board and this cable could have be dislodged and the results is no screen.
Oct 11, 2011 | Compaq Armada M700 Notebook
Powered on the media center m7260n, but no activity on the screen. I've just recently installed a new video card, even though it is new snf maybe the driver needs to be updated, I would have thought I...
I understand your problem. As you have added a new video card and do not have video when you try to boot up, are your trying both the upper case connection to see if the video is still being outputed from the original VGA source?
I would suggest that you reboot and go to BIOS, to see if your on-board video is still enabled.
I you can access your BIOS settings by pressing F2 or F6 upon bootup.
Good Luck
Aug 29, 2011 | HP Media Center m7260n (EG642AA) PC...
How 2 solve the poor video quality in intel hd graphics of acer aspire 4745? i recently bought acer aspire 4745 (core i5 430m processor, 3gb ddr3 ram)...i dont ve any integrated gpu in it...it shows the...
1. check your display settings for the best possible screen resolution for your laptop.
2. the new CPU that is installed is defaulted at 1080p resolution and is to strong for the video graphics card that is on the mother board which is possibly 1280X740 . Being a laptop and the video graphics is built into the mother board therefore possibly not compatible with the new processor.
3.
Blue ray video is ultra high resolution such as 1920X1080 HDTV
Jul 31, 2010 | Acer Computers & Internet
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
Intel PENTIUM 4 865GV MOTHER BOARD doesn't give diplay
check whether with out display if any beeping sounds are coming and hard disks are running. if possible try to place a video card and then check the output.
Apr 19, 2009 | Computers & Internet
9600GT No Display
Have you put another power cable to the back of the Video card. There is a slot on the back of the GT for more power. Once that is plugged in beeps will stop and you should recieve signal
Feb 09, 2009 | ASUS PCI EXPRESS 2.0 GEFORCE 9600GT 512M...
Booting problem
remove the ram & reinstall it again
Sep 01, 2008 | Intel D102GGC2 Motherboard
Mother board
what is the motherboard !?
- if it has an incorporated video card, first connect the display to that video output !
- does it make any sounds ?!
- is everything pluged in propperly ?!
- remove the motherboard from the case, and than make all connections in such a way that it does not touch the case - mayby u have a faulty power suplly and shorts the motherboard ...
- and ofecourse , is the display working ? :)-
Aug 08, 2008 | Computers & Internet
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Viper MSNV-939 ATX Socket 939
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop. Also assuming you bought the ram from the same place and is compatible with the board. Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual. The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip. That's not to say that the motherboard was'nt faulty in the first place.
Apr 18, 2007 | Mach Speed (S755) Motherboard
ECS 945GZT-M (V1.0) Motherboard Logo
341 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Steven Wander
Steven Wander
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
