Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wireless and internet
WORKS!
Router works fine on wired connection.
Wireless connects to router with strong signal and has full functionality.
Doesn't work?
Wireless connection unable to get connected to internet. Is there a switch somewhere that turns on internet connection for wireless? internet works fine on hard wire connection
  • Anonymous Jan 25, 2008
    I may have a similar problem with my router.  I can connect to the router over wireless, but it requires a reset every time.  Once reset, the connection works fine until the next day.  Tried calling tech support, but the connection keeps getting cut off and then I have to start all over.  Tired of repeating all this.
Same problem with wireless. Wireless connect, and the next day it doesn't work. I have to reset the connection. Still same problem, with static ip on wireless pc.
Posted on Feb 01, 2008
    Problem Solver:
  • 21 Answers
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
  • edhel joy callo Feb 02, 2008
    Try accessing router's configuration page, then change your channel. You can do this by typing your default gateway on your browser. Usually 192.168.1.1, then use admin as password. Go to wireless tab and change your channel there.
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I have a 655 router.. running windows7 on one computer on Home Network.. Router initially working OK..computer connected via cat5 wire. Disconnected router, moved to new location on desk...reconnected...
You can reset both the modem and the router by removing the power cord where it connects into the router (Called Recycling the Power) I would do it with both the modem and the router for about a full 2 minutes.
Sounds more like you have a connectivity issue from interference from something on you desk. Some known culprits are:
High Intensity Lamps Fans Radio Interference coming from your wireless phone Power strip with filters for telephone signal any other environmental issues including computer monitor. Next door neighbor's router signal bleeding through. Filter device missing from phone Filter device missing from phone line connected to you TV
Try moving the router back to the old location. Does problem go away. You are now too close to something thats breaking your signal. I can log into my neighbors access point across the street and two houses away. Signals are strong but can be blocked by a lot of things mentioned above or tin foil.
Check it out,
TF
Jun 03, 2011 | D-Link DIR-655 Wireless Router
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computer will not connect to wireless router
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Wireless G and Comcast cable internet
Im not sure about the monopoly thing?
But it must the settings that is causing a problem.
If I understand you concern correctly your computer is connecting to the router wirelessly, is that right?
and can you get online if the computer is wired directly to the router?
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Internet problem
Are you attempting to access your own wireless router? Do you know how to access your wireless router configuration? Does your wireless router support wired connections? If so, does your computer work on the on the wired connection? What is the manufacturer and model of the wireless router, laptop computer and if a separate accessory the wireless network card?
Thanks
Dec 05, 2007 | Computers & Internet
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
1,129 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
