Question about Maytag MSD2756G Side by Side Refrigerator
GARAGE FRIDGE STILL TRIPPING THE GFCI ....WHY?
I have no idea why this is happening...I reset the breaker, the fridge comes on, runs for a while, then trips the breaker again...could the cold in my garage be affecting this?
  • SPAPA Jan 23, 2008
    Is the cold able to kill the compressor?
  • SPAPA Feb 06, 2008
    well...now, the fridge trips the GFCI as soon as I plug it in....what now?
If your frig is plugged directly into a GFCI, you need to remove the GFCI and replace it with a standard plug. No one should have a GFCi behind a refrigerator.
Posted on Mar 08, 2009
Often the door-operated switch which controls the refrigerator cabin light becomes faulty (generaly caused by water entering the switch and/or corrosion. Solution: replace light switch.
Posted on Mar 15, 2008
    Master:
  • 619 Answers
Hi, test with amphere tester one of the wire of compressor let refregerator run monitor the amphere reading set to 15 amphere the tester if exceed the compressor having a problem struck need a repairman near you.
Posted on Jan 23, 2008
I have an LG refrigerator freezer model number GR-S392GC that keeps tripping the power box. I plugged the fridge into another source but it kept shorting out. I isolated the issue to the harness wire...
the concept for a DRYER is the same for a washer or fridge in some instances
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 28, 2015 | LG Refrigerators
Refrigerator disables all outlets on its circuit but the 1st outlet
I just answered your question on the previous situation but here it is again. A GFCI receptacle placed in a circuit controls power to all remaining devices on that circuit. If the GFCI trips, anything after it shuts down. That is your situation. If your fridge keeps tripping the GFCI, it has a grounding problem. You should have your fridge checked out so that your family does not receive an electrical shock when contacting the fridge. Be safe.
Aug 31, 2014 | Electrical Supplies
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Our refrigerator keeps tripping the gfci outlet it is plugged into in our garage. After several days we tried it again, and it worked for a while before tripping it again. We cleaned out the bottom...
first thing to do if it is continually tripping is to replace the gfci. they do go bad over time. Shut the breaker off to it. remove and note which wires go to which screw. if it gets wired wrong because going by memory. tis not fun trying to figure it out.
Best of luck
hope this helps and solves it. It should, if not call a tech for the fridge. or post model and make and we can go from there.
Jan 07, 2018 | Roper RT21AKXKQ Top Freezer Refrigerator
My side by side refrigerator started tripping the ground fault protector on the plug after being in the garage and working well. I have had the refrigerator for 10 years and this is the first problem I...
First question I would have is if the outlet is a dedicated line with nothing else on it. Also, does the GFCI in question have a high enough amperage rating for the refridgerator. Next, make sure the circuit breaker is not also a GFCI circuit breaker. You cannot have a redundant GFCI in the same circuit, one or the other. It can be very tricky to put an appliance like that on a GFCI circuit due to its compressor motor. Motors have a large amperage draw on them when they start so, if your fridge runs at around 10 amps, it can take three times as much to start (30 amps) which would trip a 20 amp GFCI.
Nov 29, 2010 | Frigidaire FRT15G4B Top Freezer...
Fridge keeps tripping the circuit breaker
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Power failure
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
Jul 28, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
GARAGE FRIDGE DIED...IS IT THE COLD?
No it has no sensor it sounds like the circuit breaker has tripped or the is no power at the plug..try plugging a radio or lamp in to the plug to test
Jan 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
429 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
