Question about Philips Magnavox 27MS343S 27" TV
No picture HI My problem is, when I try to turn on my TV is the power button just blank two or thee time, then goes back off. Can you please help me. Will unpluging it help me. Think you
    Genius:
  • 1,139 Answers
Hello MrJunebug,
You may have a problem with the IHVT (Integrated High Voltage Transformer). If this is the case I would suggest that you have a qualified TV technician fix this problem for you.
I hope this helps,
Thank you,
Shuttle83
Posted on Jan 28, 2008
6ya staff
SOURCE:
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
While I am watching TV on my Sony kdf-60xs955, the screen goes blank and the green light just flashes. Sometimes it comes back on and sometimes not. I hit the power button and the red light flashes 5...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Check by changing the Power cable to any other wall outlet in your home
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have no picture. After the power button is
Hi Friend,
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Regards,
Ayyasam
Apr 03, 2010 | Akai PT4298HD Rear Projection Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Won't turn on
Can u tell me model no and brand name so that i can help u sir..
Sep 03, 2008 | Samsung PCN5425R 54" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
