Question about Sharp CD-E67 CD Shelf System
Need help i need help with the alarm clock! i did it onece and now it wont let me do it again! help!
    New Friend:
  • 4 Answers
You have to make shure its off and then click the clock button and use the tuner buttons to chang time
Posted on Oct 02, 2013
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
Discovery rocket ship clock alarm off
You have to press the alarm setup, then press the up button. This turns the alarm off completely. If you want the alarm to go off again tomorrow you will have to set it again.
Feb 10, 2013 | Discovery Channel Discovery Kids - Rocket...
Setting time on wincraft desk clock
Directions for Desk Clock - Without the C?/F? button
To change the Temperature:
Press the "S" button once (this will change from Fahrenheit to Celsius)
To change the Time and Date:
Press the "M" button once to change time to or from military time
Press the "S" button once to change the hour
Press the "S" button again to change the minute
Press the "S" button again to change the year
Changing the year will also change the day of the week
Press the "S" again to change the month
Press the "S" again to change the date
To set the Alarm:
Press the button with an alarm clock on it
A flashing 12:00 should appear
Press the arrows to set the hour
Press the "S" button again to set the minutes
Press the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options
To turn the alarm functions completely off:
Press the button with the alarm clock on it
Press the "S" button five times
When three dashes appear where the time would be, it is off.
Press the "M" button three times to get back to the main clock function
To clear the secondary clock:
You can set two different times on the clock, so if you travel frequently you can have a home time with alarm and a travel time with alarm saved and ready to go. There is a primary time, the one you normally see on the clock with an alarm clock function after it. There is also a secondary time with an alarm function after it.
Clearing the secondary clock will make it easier to know when you get back to the primary clock function.
Press the "S" button seven times
Press the "M" button two more times
And you are Done!
Jan 02, 2012 | Wincraft FLORIDA GATORS OFFICIAL THE SWAMP...
Can not get the clock or alarm off the 24 hour clock!!! very annoying!!
  1. Try pressing the "MODE" button until the time setting flashes.
  2. Now press the "2" button (right under the screen) and simply advance the clock past 24:00 and the clock will enter 12 hour mode again.
  • Now the time and alarm will be in regular 12 hour time as well automatically.
  • If for some reason it is not then just reset the alarm by
  1. Pressing "MODE" until the alarm time and icon flashes on the screen.
  2. Press "1" to decrease and "2" to increase hours.
  3. Press "3" to decrease and "4" to increase
  4. Press "5" to select the alarm volume.
  5. Press ALM "OFF/ON" to activate/deactivate the alarm.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 25, 2011 | Sharper Image SI785 Clock Radio
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
Alarm goes off every day. Want to turn it off!
Under the heading ALARM are 3 buttons. One says RADIO, one says CD, and one says NATURE. If any of these buttons are selected, the alarm will go off. So make sure none are selected, and the alarm won't sound.
May 15, 2009 | Timex T601GT Clock Radio
Need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Mar 25, 2009 | Audio Players & Recorders
Setting Clock
when you press time/wake the first time the 1 for alarm clock is flashing... if you need to set this time use the arrows, if not press time/wake again; the 2 for alarm clock is flashing... same if you need to set use the arrows, if not press time/awake again and a clock appears at the left hand corner, here you can set the clock by using the arrows... good luck! you continue in this fashion...
Mar 04, 2008 | Audio Players & Recorders
Sharp CD-E67 CD Shelf System Logo
144 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
