Hi experts,
I've just bought a T4501 (Chinese version of Motorola Talkabout T4500), one of the handset doesn't work properly. Though the problematic one can send/talk to the other, but it cannot receive any response from the working one. Any advise will do. thanks in advance. & more power.
anthony
What you are describing indicated the "code" is not set the same on both radios. Check your frequency, interference code eliminator and Qt filter (if any). All the settings must be identical between the two radios. If you are still having issues, set your code and Qt filter (if any) to zero (off) and then try it. Lastly, check your batteries. Bad or poorly charged batteries can cause transmit issues, as it takes more power to transmit than to receive.
Here's a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
