Question about Philips GoGear HDD1830 MP3 Player
How want to use one of my pictures as my screensaver how do i do it
  • 8,596 Answers
IMPORTANT: Do not drag and drop pictures into the GoGear with Windows Media Player or Windows Explorer. Also ONLY JPG/JPEG images are supported.
First check your computer to see if you have the latest version of the Philips Plug-in installed.
  1. Click Start > Control Panel > Add or Remove Program.
  2. Search and select Philips Device Plug-in. Click “Click here for support information” to check the version.
  3. If you already have the latest version (V3.13.00 for HDD6330 or HDD6320) (V3.14.00 for HDD1420, HDD1620, HDD1630, HDD1635 or HDD1830) then there is no need to upgrade.
If you need to upgrade your Philips Plug-in:
  1. Launch Internet Explorer
  2. Go to the Philips support site at http://www.ph ilips.com/support
  3. Select your country & language.
  4. Enter the model number and click on "Search".
  5. Select the model number if there is more than one listed.
  6. Click on Software & drivers on the left-side menu.
  7. Double click the respective language under PC Software to save the exe file on your PC.
  8. Download the file to your Desktop on your PC.
  9. Run the LM_XXX.exe to start the installation.
  10. Follow the screen instructions to complete the installation of Philips device plug-in.
Once you have the latest version of the Philips Plug-in installed, please follow the below steps to transfer your picture(s) onto your GoGear.
  1. Launch Windows Media Player.
  2. Go to File> Help> About Windows Media Player to check if the ve rsion is 10. If not uninstall your existing version of Windows Media Player and install the correct version of Windows Media Player from the installation CD1 or Microsoft's website.
  3. Make sure the Philips Plug-in is installed on your PC. To check whether this Plug-in is available on your computer, go to Start> Control Panel> Add or Remove Programs and check if Philips Device Plug-in is listed. If not, re-install the software from the installation CD2.
  4. Check and make sure that the "Enable picture support for devices" option on Windows Media Player has been selected.
  5. Go to File> Add to library. From the menu, choose to add pictures from folder or by searching your computer. These files will be added to your library.
    Note! Files that are directly under “My pictures” should be saved in a s ub-folder before adding them to your library. If you do not do this they will show up in Windows Media Player with the event name “Unknown” and they will not show on your player.
  6. Click on the Library tab. Go to All Pictures. Click to highlight the item you want to copy. Right click on the item and select Add to> Sync List.
  7. Click on the Sync tab and select "Sync List". Choose Philips as your destination in the device pane.
  8. Click on the "Start Sync" button in the top left corner to start the transfer. Once the images start to synchronize the computer will show:
    (If you cannot see the above Philips Device Plug-in pop up, your Philips device plug in may not be installed properly. Please uninstall and reinstall Windows Media Player& nbsp;using both installation CD ROMs.)
  9. After the transfer is complete unplug the GoGear from the computer.
  10. You can then view pictures (thumbnail view and full picture view) from the Pictures menu.
Posted on Apr 08, 2008
6ya staff
SOURCE:
How do I make my screensaver pictures smaller? My slideshow screensaver pictures are to big for the screen.
In the settings of the actual screensaver. You can click stretch to screen or actual size, Experiment with that.
Sep 23, 2014 | Computers & Internet
Tip
My Pictures Slideshow screensaver
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Stuck screensaver
Restart your computer. If the images aren't removed after the restart then I suggest that you install RadarSYnc and scan your computer with it. Then update all out-of-date drivers in your computer.
David
Jul 06, 2013 | Computers & Internet
How can i change my screensaver to apicture i want
go to the photo,press menu and it will give you an opton to use it as a screensaver
Sep 28, 2009 | Samsung S8300 Ultra Touch platinium-red...
Screensaver software
Well this phone does not support screen saver feature.
you may however install additional software.
http://www.google.co.in/search?hl=en&source=hp&q=screensaver+for+n72&meta=&aq=f&oq=
Hope, this helps
Aug 27, 2009 | Nokia N72 Cellular Phone
Screensaver 4 n72
go to galleries ,select graphics & then screen saver .from here u will get screen saver provided by & if u want ur file as screen saver ,go to that picture open it , open options->use image->set as screen saver
Aug 05, 2009 | Nokia N72 Cellular Phone
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Screensaver
P. 23 of your manual will tell you how to access the screensaver option from the menu of the player. Go to RCA's website if you are missing the manual.
May 03, 2008 | RCA OPAL M4001 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
163 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
