Question about Kenwood KRF-V5060D Receiver
Increase AM bandwidth to 531khz to 1700khz
My current Kenwood KRF-V5200D audio video control centre has a AM/FM reciever. The AM band is 531khz to 1602khz. There is a radio station on 1670khz that I want to be able to listen to. Is there anyway that the AM bandwidth can be increased to 1700khz.
my email address is theolymberis@unwired.com.au
    Genius:
  • 1,067 Answers
Ya am booster antenna of the am output u could try 1st or u saying teh kenwood limites u to 1620 max only ch >
Posted on Jan 23, 2008
Connecting ps3 receiver
buy a optical cable and connect between PS to the amplifier or take the optical out from the TCL to the amplifier and select optical in,
Oct 19, 2013 | Kenwood Audio Players & Recorders
Kenwood krf v5300d
I'd Google "Kenwood KRF V5300D remote control". Surely you will find a replacement available from someone. This worked for me to find one for a LG BluRay player.
I found them in the UK for example, at http://www.findremotes.com/remote-controls-1/kenwood-remote-controls-krfv5300d-1238517.htm
Oct 13, 2013 | Audio Players & Recorders
Reciever keeps yurning itself off after a few seconds
Assuming running from a cold start,
it means protection circuit are activated.
If it runs hot, then turns off then it is thermal cause.
Simple solution could be disconnecting all your speakers
and power up.
If it runs OK, then reconnect one at a time to find the cause.
If disconnecting the speakers doesnt do anything,
these unit needs repair.
Start checking out power supply
Check the supply rails to the main amp ( B+ and B-)
and most important , check for DC offset voltage on all amp outputs.
Let me know if you need further assistance!
Sep 27, 2012 | Kenwood Audio Players & Recorders
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
I have a Kenwood KRF v5200d audio video control center that worked great for 2 years . It is just out of warranty and is now giving problems. It turns on for about 15 seconds and then cut out and goes into...
i'm not the perfect expert in this but did you try removing all speaker,rca,s video, etc from the back and seeing if something maybe back feeding to the receiver. the red light blinking usually means its detecting a short somewhere and it goes in a fail safe mode to prevent more damage. if it stays on with everything disconnected the problem is with something else. try them one at a time to isolate the problem. hope this helps thank you.
Jan 01, 2011 | Kenwood Audio Players & Recorders
My kenwood krf-v4060d reciever on/off switch is faulty, it stays switched on for a few seconds and then switchs its self off.can i get a replacement ? i have had not much luck here,any suggestions !
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Dec 09, 2009 | Kenwood Audio Players & Recorders
Music, sound effects no dialogue
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
May 14, 2009 | Kenwood KRF-V5060D Receiver
I have a brand new kenwood krf-v5200d amp. when I turned it on the first time it when't straight to the standby light blinking. I have checked all speakers and they are connect correctly. Any idears
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
Nov 29, 2008 | Kenwood Audio Players & Recorders
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
Kenwood KRF-V5060D Receiver Logo
113 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
