Question about Nokia 6131 Cellular Phone
Phone will not turn on
Took battery off, put battery on, fully charged, I press the power button, phone will not turn on.this happen when i was doing FV update Help! Thanks!
  • Magpie01
    Magpie01 Jan 25, 2008
    Thanks for 'joshy999'that will try to get some one to do it .
  • 241 Answers
Your firmware is probably messed up a bit - you will need to redo a complete flash - but not with usb cable - you will need proper equipment like JAF - but you don't need to spend $300 for a tool - we can fix it for you for under $30
Posted on Jan 23, 2008
My galaxy r don't open again after the battery drained. When I charged it there's sign that it is charging but I cant open once I hold the power button
I don't have that particular phone, but my phone has a small LED in the front that turns to red when it's in the charger with a fully drained battery, yellow when it's above 20% charge, and green when it's fully charged.
If the phone is fully charged, but it won't turn on when you press the power button, there's probably a problem with either your charger or the battery itself. I suggest replacing the battery, or when it's built into the phone itself visit the store where you bought it. They might know what to do.
Nov 26, 2014 | Computers & Internet
I put my U5i to charge and when I woke up in the morning it was shut down and I can't turn it on...In two words the phone died.
Did you drop the phone in water recently? Did you get it wet in the rain? Apart from the likely possibility that the phone is actually damaged/battery damaged, this happens if the power button gets damaged. When you put the phone to charge, in the middle of the night the power button "acted" as if it was pressed and held and the phone turned off. Now when you press the power button, nothing happens because the power button is damaged.
Take it to a repair shop and check the power button for damage. It is replaceable and should not cost a lot.
Does your phone have a removable battery? If yes then you might be in luck. If not, then just take the phone to repair shop and get the power button checked and repaired.
If battery is removable I know that it is possible to turn on the phone this way:
1) Plug in the charger to the phone
2) Remove the battery and insert it immediately. Do this multiple times and the phone should turn on without having to press the power button.
Hope that works.
Sep 27, 2013 | Sony Ericsson Vivaz U5i ruby Red Unlocked,...
My droid incredible2 won`t turn on. how do i reboot it
Charge the phone for 10 minutes.
Press down the volume up button and hold it and then press the power button for a few seconds . The device will restart.
Dec 16, 2017 | Cell Phones
I hit a button on phone, screen went blank, not able to dial. I put in the charger and it is fully charged
If battery is charged and phone is working simply do this: Press the power button for a few seconds, which is the same as the "hang up" button with red ink on it). Voila! It took me serveral days and a number of dealers telling me I had to pend $300 for a new phone before I uncovered this fix.
Feb 16, 2010 | Panasonic KX-TD7896 Cordless Phone
Does my phone have to fully charge before i can use it again?
No, try and remove the battery again. wait a few minutes.
Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
Any more questions just ask.
Feb 07, 2010 | Motorola Mobility RAZR V3
My phone froze so i took the battery out and now when i turn it on all it does is stay on the sprint loading page how do i fix it?
take the battery out and hold the power key for about 20 seconds then put it back in fully charge the phone then try to power it up without the charger connected to it and see what happens
Jul 22, 2009 | Samsung SGH-U600 Cellular Phone
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Phone Wont Turn On
unfortunately, you'll have to do a master reset on your phone. You'll loose all of your data. TO do this.. power off the phone. Then press the center select button (silver button on navigation pad) then power on the phone while keeping the sliver button pressed. You should get a Master reset prompt.. click Yes.
Apr 11, 2008 | Motorola Mobility Moto Q
there is problem inside ur phone for which is causing "local mode" u should take it to technician.
Jan 20, 2008 | Nokia 6131 Cellular Phone
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Nokia 6131 Cellular Phone Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
